carbu tuning
Old Sep 13, 2013 | 02:25 PM
gab's Avatar
gab
gab is on a distinguished road
carbu tuning
hi guys i bought a vtr99 stock except kn air filter with dyno jet. the bike was running very well with 190 main jet......(seem to much but as a said was running great) i just install a exhaust and mod the intake.Now the low end still good but mid range with half trottle is bugging and with full trottle it pull fine but not as much as before. I did a plug test and they are white..lean... What jet are you should i buy since i have the choose of 192-195-198-200.. should i got direct with 200 or should i buy all these...i know its all try and mistake...
thks any advise are welcome
Old Sep 13, 2013 | 03:04 PM
jerryh's Avatar
Hey gab do a search man. Seems like many prefer oem filter
Old Sep 13, 2013 | 03:42 PM
HRCA#1's Avatar
I strongly suggest you read the Carb Setup Thread by Hawk8541, it's a stcky so not hard to find. You are going in the wrong direction entirely! There is no way that you are lean unless you have engine mods you haven't mentioned.
Also the dyno jet main jets are numbered/sized differently from OEM. A 190 dynojet is not the same as an OEM 190, be sure you know what you have before buying anything!
Old Sep 13, 2013 | 04:18 PM
gab's Avatar
gab
yes i know for the oem filter thks
wow i didnt know they were size differently and reread the hawk8541 treads completly and find all i need
thks guys
Old Sep 15, 2013 | 06:41 PM
gab's Avatar
gab
hi guys i just remove my carbs and setting up to do some mods. where i can find some jets since jetsrus.com is a little complicated because im not from the us. And whats the tricks for the Fuel Mixture Screws because mind are in d shape.. i read that some had grind them to fit a flat srew driver but mind are deep and not moving since i dont have the tool...
Old Sep 15, 2013 | 07:28 PM
Responded in carb setup thread.
Old Sep 15, 2013 | 08:12 PM
CrankenFine's Avatar
Ditto.
Old Sep 16, 2013 | 09:48 AM
JamieDaugherty's Avatar
Check out my response #299 to that thread. Probably best not to jet using settings from a forum thread - FYI.
Stevebis1
Sep 28, 2010 10:39 PM
loserbaby
Sep 21, 2007 10:36 PM
superhawk06
Feb 4, 2007 06:48 PM
EngineNoO9
Oct 12, 2006 06:50 PM
channidai
Jul 8, 2005 07:10 AM
