Calipers for the superhawk...
Old Nov 8, 2006 | 07:07 AM
Randman's Avatar
Moderate-whore
Anyone know which or any of these will fit the stock forks, in otherwords bolt right up, or small amount of grinding????
1998-up zx9
rc51 what years?
99 TLS??
TLR ??
any others that will work....and what combination, ie with the stock M/C and cables...or with a diff M/C or cables....
I a looking at the RC51 00-01 with M/C to add....will my ss lines work, I think it will, I just need someone smarter than me to tell me they will...
TIA to all
Old Nov 8, 2006 | 07:57 AM
superhawk22's Avatar
1998-up zx9
rc51 what years?
99 TLS??
TLR ??
TIA to all
No
All
NO
No
The distance in between mounts on the ZX and the TL's is too large and won't bolt up. The RC calipers should all be the same and the lines will work fine. The only 6 pot type that fit are the 01-02 gsxr1000, although the sv1000 4 pot calipers will fit as well.
Old Nov 8, 2006 | 08:00 AM
Randman's Avatar
Moderate-whore
Ok, thanks, now I can do what I should have done a long time ago....
Old Nov 8, 2006 | 08:05 AM
Give up? The 929/954 calipers work with a little grinding as well as the F4's or you can go crazy and change the front end and get bigger rotors with it as well.
Old Nov 8, 2006 | 08:06 AM
Randman's Avatar
Moderate-whore
Give up,,,,,that is a good idea....None the less I need brakes, so I think I am going to keep looking..
Old Nov 8, 2006 | 08:08 AM
What you showed me looks pretty good.
Old Nov 8, 2006 | 08:10 AM
Randman's Avatar
Moderate-whore
Don't tell the others, they will get jealous!!
Old Nov 8, 2006 | 08:16 AM
But they were sooo big!
Old Nov 8, 2006 | 08:17 AM
Randman's Avatar
Moderate-whore
I mean I don't like to Brag or anything, but geeezzz.... :-D :-D
Old Nov 8, 2006 | 08:31 AM
Lefin102's Avatar
Get the whole RC51 system if you want to fix the problem. The master on the VTR has a 14mm bore. Not as good as the 19mm bore on the RC.
Old Nov 19, 2006 | 12:56 PM
Randman's Avatar
Moderate-whore
Well the RC51 calipers don't just bolt right up, there is some grinding to do, now for a stupid question, what do you grind?? the part of the caliper that meets with the forks, or the part of the fork that meets with the caliper??
Anyone, superhawk22, Greg, etc.....
Old Nov 19, 2006 | 01:00 PM
You grind the caliper, not the mount. Grinding the mount would achieve the same result but would weaken it. That not good.
Old Nov 19, 2006 | 01:02 PM
Randman's Avatar
Moderate-whore
Gottcha, I kind of figured that, but wanted a second, more educated opinion in this matter before I really screwed things up....Thanks
Old Nov 19, 2006 | 01:28 PM
Well, your first mistake is assuming that either 22 or myself are "more educated".
Old Nov 19, 2006 | 05:06 PM
Randman's Avatar
Moderate-whore
How about a more experienced opionion..From a couple of old guys..LOL...:-D
Thanks for the info...
Old Nov 20, 2006 | 06:29 AM
Yeah, what was HE thinking?
If you do a search someone has detailed pictures of where and how to grind them, I think it was on jschmidt's thread.
98blackhawk
Nov 30, 2013 10:05 AM
Rollin20z
May 9, 2012 10:28 AM
HAWK-89-GT.va757
May 15, 2011 06:30 PM
mikstr
Apr 15, 2007 08:16 PM
roadrun_fr
Sep 11, 2005 11:33 AM
