Anyone know how to install jet kit?
Old Mar 17, 2010 | 05:15 PM
steve29's Avatar
steve29 is on a distinguished road
Hello. Just recently bought 2000 Hawk. It came to my attention that the previous owner didn't jet the carbs when he put on the aftermarket exhaust. So, in order to save money, I want to attempt it myself. Few questions. Stage one or two? As a novice mechanic, is this something I can handle? Any advice or first hand experience would be helpful. Thanks guys.
Old Mar 17, 2010 | 05:55 PM
residentg's Avatar
do a search on "jets", you do not need to buy a jet kit if you are trying to save money. You can shim needles and replace individual jets. JB
Old Mar 17, 2010 | 05:59 PM
Carb r and r and installing jets and needles is not something I would recommend for a novice mechanic. Especially the carb r and r part...a pain in the *** on this bike in my opinion.
If it's running okay with no flat spots through the rpm range, you may not need to rejet. But even with stock exhaust, the SuperHawk benefits from some carb work, and with aftermarket exhaust you are most likely running too lean.
Oh, and welcome. You may want to formally introduce yourself to the Unofficial Superhawk Forum. You'll probably get better response to your questions.
Old Mar 17, 2010 | 06:08 PM
It's all been talked about in the last couple of weeks, a search should give you all the info you need.
Old Mar 18, 2010 | 12:59 PM
steve29's Avatar
Thanks for the info guys. Bike definitely has flat spots in first and second gear at low rpm. I'll probably leave the work to someone who knows what they are doing.
kardiac996
Oct 2, 2012 04:57 PM
SloBlue
May 14, 2011 07:55 AM
Rama
Dec 15, 2010 07:49 AM
YTKinWI
Sep 3, 2010 05:29 PM
Partsman
May 7, 2010 09:08 PM
