Airbox Modification
Old May 6, 2005 | 11:43 PM
Airbox Modification
just bought a 1998 super hawk and later found that the top of the air box (the airbox lid) had been cut off.. is this a normal, well known mod? should i keep it or ditch it and get a new cover?
thanks.
p.s. anyone know a good way to clean up a title?
Old May 9, 2005 | 12:07 PM
Re: Airbox Modification
bump
Old May 9, 2005 | 01:27 PM
faz's Avatar
faz
faz
No, it is not normal.
I am not sure if it causes any performance flaws/improvements.
What do you mean clean up a title?? as in "salvaged" title?? I believe it can't be done.
Old May 9, 2005 | 02:31 PM
ClevelandSuperhawkRumble's Avatar
im assuming the airbox lid was cut cus the bike was running rich and the previous owner had no idea what he was doing and wanted to let more air in. get a new lid. you want to KEEP your pistons, so running it THAT lean would be a bad idea.
as for a salvage title.. the "cleanest" a salvage bike can get is a "salvage rebuilt " title status . ofcourse you lose a great deal of your market blue book value( roughly 10-15% ) cus its a salvage rebuilt title. this title label means the bike was wrecked beyond drivibility legally on state roads and then it was fixed up(frame,subframe, plastic, sharp edges on aesthetic pieces, etc) to make it road worthy.
Old May 9, 2005 | 03:44 PM
Monomaster's Avatar
Monomaster
I've never met anybody that suggests modifying the airbox by cutting holes in it....even in racing applications...
All experimentation involving reshaping or enlarging the standard airbox have resulted in a proportionate loss of power. Racers in the late 90's eventually went back to the standard configuration.
My suggestion would be to go buy another airbox cover from a wreckers..
Old May 9, 2005 | 04:16 PM
forget cutting holes in it... this guy cut the entire top off and only left a ring in which to bolt down the air filter. too bad i can't find a top on ebay. as for the title i know about the "rebuilt salvage" title here in arizona, but i've also heard that nevada is pretty lienient, and you can sometimes get away with fixing the title there.
thanks for the help
Old May 9, 2005 | 08:07 PM
jschmidt's Avatar
jschmidt
Just buy a new top. You can ride it until you get one. It won't damage anything.
Old May 11, 2005 | 03:23 AM
BooYeah's Avatar
BooYeah
the only way i have ever heard of fixing a title, an i am strongly against this unless it is checked by a shop.
by a frame off someone who wrecked a bike without insurance and swap everything on your bike on to it and title with that title.
only due this if someone professonial has checked the fram and don't be shifty let the next guy know about it.
Old May 11, 2005 | 12:09 PM
RVO27's Avatar
RVO27
Here's a link to a replacement airbox on Ebay
Superhawk Replacement Airbox
Old Jun 5, 2005 | 09:13 AM
pigwings's Avatar
pigwings
Dealers here will only give you 1/2 of KBB.com trade-in value with a reconstructed title.
Old Jun 6, 2005 | 12:49 PM
RymerC's Avatar
RymerC
that's an interesting modification. I know when I took the sidecover off the airbox of my old 750, I love the growl it made under load...even if it lost 1/2 hp or something silly.
I wish I could hear more intake noise on the vtr, but I don't want to kill driveability? I'm really interested to know how this turns out for ya daz, le me know!
Old Jun 6, 2005 | 11:36 PM
Originally Posted by stormsmasher";p=&quot
I will actually try it myself in the next couple of weeks since I have a replacement airbox to mess with..... I'll report back my findings when I know more.
please do, so i know whether or not to throw away this old air box ring.
thanks
Old Jun 7, 2005 | 07:24 AM
jschmidt's Avatar
jschmidt
Racing modifications are often not transferable to a street bike. Even if this one works, it would only benefit WOT. It would certainly not improve tractability throughout the rev range or wet weather operation. An unprotected paper filter is destroyed the first time it gets soaked.
Old Jun 9, 2005 | 09:57 AM
Pachucos's Avatar
Pachucos
I would say it is somewhat normal Mod.
I actually remove my top and only have the BMC air filter installed and screwed down.
I have seen others here the same way.
As for performance gains i would say yes but slight. you need to have the carbs set right because you will run lean if not.
Old Jul 11, 2005 | 09:49 AM
Rollingalong's Avatar
Rollingalong
Any HP gains from mods to the stock airbox on a VTR1000F will only come at stage III level after pistons ,cams , larger valves and racing exhaust have been done .
In fact , if the top has been totally removed you will be sucking hot air instead of the relative fresh air that can be had from the snorkel at the front of the engine .
The cooler the air , the better .
Old Jul 20, 2005 | 07:28 PM
Gerrit's Avatar
Gerrit is an unknown quantity at this point
RAM AIR!
I have seen that somewhere? Moriwaki?
Don't now, anyone?
Old Jul 25, 2005 | 02:47 PM
bluesman's Avatar
bluesman
RAM AIR!
Don't now, anyone?
Here
http://folk.uio.no/joakimt/vtr/pictures.html
Check RUMI - tuned VTR...
Old Jul 28, 2005 | 09:50 AM
VTRFISH's Avatar
VTRFISH
I friend built a ram air for his TL.
Started with a piece of cardboard lined with handy wrap, removed stock air box, placed cardboard over carbs....under mounted tank( under side covered in handy wrap), injected expanding foam insulation in the "air box" void.
After the foam dried he had a perfect mold for fiberglassing a box of max size......addes hoses with in hose K&N dual filters.
Mike
flngscout
Jun 12, 2008 02:49 AM
darylward
Mar 19, 2008 01:57 PM
Slim
Feb 7, 2008 01:44 AM
steve365
Nov 7, 2005 04:27 AM
Besucher98
Oct 24, 2005 03:52 AM
