954/929 brake mods?
Old May 23, 2014 | 01:32 PM
sailorjerry's Avatar
954/929 brake mods?
So I finally broke down and started purchasing parts for my front end swap, and I figure if I'm going to do the swap I want everything on point the first go around.
I puchased a set of 954 forks, and I am curious if anyone has tested different brake set ups on these front ends?
Or should I just stick with the stock 954 calipers and MC?
Thanks in advance
Old May 23, 2014 | 01:40 PM
The 954 calipers were so nice on mine I didn't even think to upgrade. Probably have a lot more luck searching in the Fireblades forum...
Old May 23, 2014 | 01:55 PM
Yeah I didn't scower through the fireblades forum, just did a general google search and came up with nothing execpt for people swapping 954 calipers over to their 929's
One interesting thing I did find while seaching though which I'm not sure if anyone running an F4i set up on a hawk has tried, was swapping 954 pads into the F4i calipers. Said to give better feel, modulation, and longer pad life, due to the 2mm thicker pads the 954 runs.
Old May 23, 2014 | 02:56 PM
bmidd's Avatar
bmidd is on a distinguished road
Rotors are the same. are the calipers different? The only difference it that some of the 929 rotor carriers (Y2K ?) are anodized black while they are all gold on the 954s. I have 954 rotors and 929 calipers, maybe after 2003 the 954 for a bit more piston diameter.
Old May 23, 2014 | 03:38 PM
The calipers and MC are different between the 929 and 954.
929: MC= 19mm piston Calipers= 34/30mm pistons
954: MC= 17.4625mm piston Calipers- 32/30mm pistons.
From everything I have read the 954 brakes are supposed to be much better than the 929 brakes. I have not tested either so that is just hear say for me.
Old May 23, 2014 | 05:21 PM
954 pads on f4i brakes? Maybe I will try that next time I need pads.
Aren't the 954 forks the shortest of the swappables or is that the RC51? Are the 954s similar to the 1000RR?
If so the swap is a cake walk. Godspeed.
Old May 23, 2014 | 08:59 PM
lloydievtr's Avatar
road racer v2 power
I'm doing this swap - 954 forks -2004 yokes-2004 calipers and master -2004 wheel and discs .
Custom caliper mount brackets . As the 2004 discs are 310 mm and not 330 mm like the 954. The reason I'm going with the smaller disc As the 954 disc warp to easy and is a common problem and I'll be radial :-) .
Also the 2004 front wheel is lighter unsure by how much tho .
Old May 23, 2014 | 11:43 PM
superbeater's Avatar
I use an '09 CBR600RR radial M/C with the 954 calipers. It's a nice set up.
Old May 24, 2014 | 09:41 AM
I'm not to sure which is the shortest set of forks..... I know that the 954 front end bolts up pretty easy with the use of the gull winged triple. I just have to figure out what I will do clip on wise, and for that I have some ideas.
Old May 24, 2014 | 10:49 AM
There is only one answer for that, Apex riser bars. Adjustable in every direction.
Old May 24, 2014 | 11:58 AM
bmidd's Avatar
Stock 929 clip-ons work just fine.
https://www.superhawkforum.com/forum...ip-info-31972/
Old May 24, 2014 | 12:44 PM
Actually I found a hohey top triple tree, it has an extra 1 inch drop from the stock 954 gull wing triple. Meaning I will be able to run my clip ons above the top triple with out dropping the front end any.
Still going to have to play with some different clip ons to get the rise that I would like but may be able to spend a little less than buying a new set of apex, but then again might end up spending more.
Still toying with some ideas here, nothing final except for the 954 forks. So we shall see.
Old May 24, 2014 | 12:46 PM
I know, I want to try something a little different with it though. Not to mention I want adjustability.
Old May 24, 2014 | 06:16 PM
bmidd's Avatar
I completely understand, I'm about one more long ride from some bar risers and a nice Renthal.
vtromey
Apr 5, 2007 04:09 PM
joshn569
Feb 14, 2007 05:10 PM
Flight_996
Jan 6, 2007 04:19 PM
selztoad
Dec 19, 2006 07:56 PM
vtromey
Nov 15, 2006 10:52 AM
