06' USD Forks & 6 Spoke Rim
Old Apr 24, 2011 | 10:12 AM
katryder1@gmail.com's Avatar
Katryder
katryder1@gmail.com is on a distinguished road
I am in the process of installing a set of USD forks from an 06 CBR1000RR on my SH. I am goin with the 6 spoke wheels from a 900RR (I have the rear already). I want to install a 17" 6 spoker on the new front forks as well. I have found one from a F4i that I can buy for cheap. My ? is will that rim fit with the new USD forks? If not then which bike will I need to rob one from? Thanks for any advice, B.
Old Apr 24, 2011 | 11:00 AM
Your best bet is to use a 6 spoke wheel from a 2000-2001 RC51, but even then I'm not sure that will be a 100% bolt on.
Old Apr 24, 2011 | 11:22 AM
The bearing size is wrong. RC wheels use 22mm bearings
Old Apr 24, 2011 | 11:53 AM
Yes, but isn't the bearing cavity larger on the RC wheel? You can get bearings any day of the week at NAPA. Trying to find a bearing with a small diameter outer race to fit the larger axle might be next to impossible. Plus the RC wheel uses 320mm rotors, although I don't know if the offset will be correct.
Old Apr 24, 2011 | 12:53 PM
You would save alot of headache using an 1000rr wheel. They bolt right up and accept the rotor to fit the fork legs.
Old Apr 24, 2011 | 03:28 PM
Agreed, and if you need spacers for a 1000RR I have 'em. Using the 929/954 upper triple with get you correct fork spacing as there's only 2mm difference between them.
Old Apr 24, 2011 | 05:30 PM
matt365's Avatar
I've got a set of spare 929 rims (same bearings) and an F4i front rim. The rims are essentially identical except for the inner diameter of the bearings.
929 is 22mm bearings, I believe the F4i is 20mm. The OD appears to be identical.
Rotor pattern was identical too.
'07 and down 1000rr rims, RC51, and 929/954 rims are all interchangeable.
Old Apr 25, 2011 | 12:43 AM
Actually that's not quite true matt... The RC51 use 22 mm ID bearings, the CBR's use 25 mm ID bearings... So no, you cannot just swap them over... Trust me on that, they won't fit...
But other than the bearings, it's correct the RC51 rims are interchangeable in terms of the rotor pattern/dimensions... And it's more than possible to find the needed bearings, the OD is identical... But RC51 rims are hard to find and expensive...
Old Apr 25, 2011 | 07:37 AM
...and f'ing heavy as all hell.
Rollin20z
Mar 17, 2016 02:07 PM
Rebirth98
Aug 14, 2015 08:06 AM
HRCA#1
Oct 13, 2012 10:20 AM
JPP
May 23, 2012 05:59 PM
VTRsupersport
Feb 29, 2012 05:09 AM
