Who's painted the little belly pan fairing thing?
Old Jun 8, 2009 | 08:52 AM
98ILVTR's Avatar
I know the paint code, but I don't know how to do automotive painting. I just got a quote for it, and they said $250, which sounds outrageous to me.
Old Jun 8, 2009 | 08:58 AM
nothing's Avatar
ride it out
I painted mine satin black cost $4 and looks ****
Old Jun 8, 2009 | 09:00 AM
I did Matte black, though I ended up spending $6 because I got a plastic primer too.. :P
Old Jun 8, 2009 | 09:04 AM
superbeater's Avatar
I just painted mine with a rattle can. Krylon Fusion paint for plastics. If you are going to paint it black or silver I would just go with Krylon. It's easy enough to re-do if it gets chipped.
If you want to color-match you can order the paint in a spray can. I think the company is Color-rite but not sure. They advertise in Cycle World and Motorcyclist magazines.
Another option would be to go to an auto parts chain store like Kragen/Chucks/Schuks/Autozone or other that carries Dupli-color and pick the nearest color. You'll probably be able to find something very close. You can spray it with clear coat and buff it out to be very nice.
A store that specializes in automotive paint in your area could give you some tips on prep and might be able to sell you a very good match in a spray can.
$250 sounds like a lot but when you consider the cost of auto quality paint, labor, prep work and business overhead, it's about right. SOmetimes shops bid high on work if they are not really interested in it.
Old Jun 8, 2009 | 09:05 AM
HRCVTR1000's Avatar
Yes ,that is outrageous ! See if you can find one of these paint reconditioning companies that goes around to car dealers doing paint repairs on used cars . Most of them will be happy to paint it for $30 or less ! I got mine painted in trade for a case of beer . I will have to admit mine has been painted twice now because of the debris coming off the front tire will slowly sandblast it over time . But it still looks better than the stock gray .
Old Jun 8, 2009 | 09:14 AM
Plasti-KoteCo., Inc. makes a near exact color & sheen match for the OEM "silver" "lower engine cowl". It is called "Ultra Vinyl Color 421 Silver Smoke Metalic", and should be available at many auto and bigbox stores.
Old Jun 8, 2009 | 09:39 AM
Billzilla15's Avatar
we use the color-rite products at the shop i work at. just did a 04 VFR it was a perfect match its expensive stuff but you get what you pay for.... and automotive paint is just plain expensive no matter which way you cut it
Old Jun 8, 2009 | 09:45 AM
98ILVTR's Avatar
Well, I want it to be painted Italian Red. I was just on Color Rite's site, and they have a Aersol can of it for $33 I believe. Then I could do the clear coat over it, and buff it. But, I am going to check with some friends to see if they know someone that can do it for cheaper. I also want to paint the front fender a gloss black to match my Jardine cans..
Old Jun 8, 2009 | 12:02 PM
good luck, post some pics when you're done i'm interested to see how it turns out
Old Jun 8, 2009 | 12:31 PM
finepooch's Avatar
truck bed liner is what i'll go with... someday!
Old Jun 8, 2009 | 01:31 PM
MOONSTER's Avatar
I'VE PAINTED MINE 2-3 TIMES OVER THE YRS. KRYLON WORKS PRETTY GOOD. THIS IS THE LASTEST VERSION.
Attached Thumbnails Who's painted the little belly pan fairing thing?-bike-pictures-002.jpg
Old Jun 8, 2009 | 09:25 PM
shayne's Avatar
As it cops damage from road debris, I painted mine with something I could touch up or repaint at home. I suggest you use a quality spray can paint of some sort, so you can do the same thing.
Old Jun 8, 2009 | 09:47 PM
HawkRider98's Avatar
I used Color Rite paint to paint my lower fairing and the belly pan. It is a perfect match. If you are going to use Color Rite you need to go all the way. Their paint is urethane based so that it flexes. So you will need to do primer, base coat, color coat and clear. They are all urethane based and made to go with each other. Looking at my lower next to the upper fairings you cannot tell a difference in color. I just replaced my right side fairing due to a kamikaze bird and the lower matches the new fairing better than the old one. I applied 3M protective film over the paint so it has been holding up very well. It is not cheap but you get what you pay for. Doing just the belly pan you can get away with one can of each easily and have paint left over.
Old Jun 9, 2009 | 03:36 AM
not completely true, you can get aways without using a primer, the original paint from Honda on that piece is a urethane based paint, you can get away with not using a primer if you scuff the paint thats on there, the paint its self needs a tooth to bite into, paint bonds in two ways theres a chemical bond and a mechanical bond, if you scuff the paint(creating a mechanical bond), using something like a 3m grey scuff pads from any auto parts store you can apply color directly to that, after making sure its super clean tho, when you scuff it you need to essentially take the shine off of it it should look dull and flat when you're done.
the Italian red comes in numerous factory variance colors, the one they list for the 98 has a base coat and a mid coat, also know as a 3 stage color (base, mid , clear), you will need both of them to make a perfect match, if you want to save some money you can buy the Italian red for a 04 VFR it comes as just a base, just put down a couple coats of red and clear it, no need for the 2 different paints, the color of the VFR is slightly lighter but you would never notice with the belly pan being so far away, if you painted the side faring and attached it to the nose piece you would panel to panel like that you would see a difference
hopefully this helped a little
Old Jun 9, 2009 | 08:11 PM
Kelevra's Avatar
Flat black with hi temp engine paint as of yesterday, looks teh bomb!
Old Jun 9, 2009 | 08:23 PM
98ILVTR's Avatar
I was gonna do the Italian Red; but if I go for Color Rite, it would cost a fortune just for a little bit of paint. Instead, I am going to do it black, like my fender, and that I can pick up for cheaper. Then I am going to do 2 coats of clearcoat, and then wet sand it, and buff it out with 3M Perfect-it Rubbing
Compound.
Old Jun 9, 2009 | 08:39 PM
raptorrider's Avatar
raptorrider is on a distinguished road
Smile Rattle can red
Painted mine the exclusive color of rattle can red by Krylon. Paint was purchased at equally exclusive paint store Walmart. All kidding aside occasionally touch it when changing oil. Looks good with red wings on tank, bike is black.
Old Jun 9, 2009 | 09:15 PM
runrowdy's Avatar
runrowdy is on a distinguished road
I color matched mine with Duplicolor Honda dark grey metallic. It matches the engine case color almost perfectly and blends in the chin fairing nicely.
Old Jun 9, 2009 | 09:54 PM
oahu hawk's Avatar
geezer
rattle can'd mine with satin black, the best chin spoiler color...
Old Jun 10, 2009 | 03:05 PM
PUSHrod's Avatar
Powder coated gold wheels, had to paint the little chin fairing gold. Duplicolor with clear.
$7 +-
Old Jun 14, 2009 | 08:53 AM
cal2az's Avatar
Az/Texas Rider
cal2az is on a distinguished road
Krylon Fusion gloss black:
Attached Thumbnails Who's painted the little belly pan fairing thing?-vtr-002.jpg   Who's painted the little belly pan fairing thing?-vtr-005.jpg
Old Jun 14, 2009 | 06:07 PM
Kelevra's Avatar
Looks great bro...!
Old Jun 14, 2009 | 06:42 PM
chickenstrip's Avatar
chickenstrip
Nice header, too!
Ceramic coating?
Old Jun 15, 2009 | 09:32 AM
cal2az's Avatar
Az/Texas Rider
Originally Posted by chickenstrip
Nice header, too!
Ceramic coating?
The header was painted with high heat, stove black paint. Rattle can.
Old Jun 15, 2009 | 09:37 AM
Dave in NY's Avatar
I did the cheap rattle can black too, came out about like cal2az pics show. Since that little spoiler is down low so it gets crap all over it anyway, I thought there was no point spending a lot of money on it. Looks fine 4 years on!
Old Jun 15, 2009 | 10:32 AM
98ILVTR's Avatar
Here is my fender and chin spoiler painted up:
https://www.superhawkforum.com/forum...4&postcount=15
Old Jun 15, 2009 | 11:10 AM
looks good!
Old Jul 29, 2009 | 01:56 AM
hondavtr1000sp2's Avatar
I painted mine with spray cans,matt black under coat,metallic charcoal base coat,3 coats of clear.
Attached Thumbnails Who's painted the little belly pan fairing thing?-2009-06-12-11-17-04_0030.jpg
Old Feb 2, 2010 | 12:06 PM
Try Dupli-color bumper coating-FB108-Medium Silver. It lays down real nice, has that cool metallic look, and topped of with a few coats of clear looks awesome.
Attached Thumbnails Who's painted the little belly pan fairing thing?-chin2.jpg
Mudkicker
Sep 20, 2013 06:18 PM
Tebs
Nov 12, 2012 03:40 AM
UltraJibus
Jun 29, 2011 05:48 PM
Alpar
May 31, 2007 08:05 PM
Ausie996
Apr 18, 2007 10:07 AM
