Polished Lip on Rims
Old Jun 22, 2006 | 05:14 AM
jtgraha2's Avatar
jtgraha2 is on a distinguished road
hey,
I was wondering how you guys go about getting such a crisp polished lip on your stock rims.
Thanks
Jon
Old Jun 22, 2006 | 06:31 AM
superhawk22's Avatar
Sand, sand, sand, sand, sand, sand, sand, sand, sand, sand, sand, sand. Wetsand, wetsand, wetsand, wetsand, wetsand, wetsand. Polish, polish, polish, polish....hope this helps. :wink: Seriously though start off with course and work your way to fine, then extra fine etc... when you get it smooth move to wet sanding, after wet sanding polish. First polish with a cutting polish and then go to a buffing polish. There are no shortcuts just hand cramping sanding, although it's better if you start out with some strong paint remover first.
Old Jun 22, 2006 | 06:36 AM
3D02's Avatar
What superhawk22 said, or.....
With something like this. You probably could find jeweler's rouge at a automotive paint store. I believe Lowe's sells metal polishing compounds also.
http://www.eastwoodco.com/shopping/p...roductID=15352
Old Jun 22, 2006 | 07:13 AM
jtgraha2's Avatar
what do you think about rigging up something to rotate the rim while I hold the sand paper? maybe a drill?
Jon
Old Jun 22, 2006 | 07:27 AM
I don't know because if you get out of line then you put in more scratches and you'll have to start over again but you could try it.
Old Jun 22, 2006 | 08:29 AM
RonVTR's Avatar
RonVTR
"what do you think about rigging up something to rotate the rim"
Disclamer... The following could be dangerous. You do this at your own risk. You could get hurt.
That said... I did this with some car wheels. I used jack stands and wheel chocks to secure a car. The wheels rotated while it idled in 4nd gear. I used emery cloth, 320 wet sand paper, steelwool/metal polish combo, and finished with soft cloth and metal polish. This worked great... and was quick too. I see the biggest problem would be in securing the bike (and it would only work for the rear wheel).
Old Jun 22, 2006 | 12:02 PM
SlowHAWK's Avatar
You can also be pretty sloppy sanding, sanding, sanding, then polishing, then mask off with tape the plished areas you want, slightly rough up the rest and paint the rims black again to get a nice edge. I'll post up pics (tonight) where I did this on my rims.
J.
Old Jun 23, 2006 | 11:43 AM
VTRFISH's Avatar
VTRFISH
A Dremel tool with one of those "floppy" 120 grit wheels was my first step.....rim off bike the best, then a ton of hand sanding and polishing.
Good luck.
Mike
8541Hawk
Jan 17, 2013 02:46 PM
scottiemann
Apr 26, 2012 11:49 AM
PRTSMN
Sep 20, 2008 03:11 PM
AKohler996
Aug 3, 2007 07:47 AM
mrjakeanderson
May 20, 2005 09:06 PM
