Paint refinishing
Old May 12, 2009 | 01:42 PM
steve.g's Avatar
Paint refinishing
Hey Guys,
friend of mine painted my bike and the finish was a little abrasive so he buffed it. Now the paint is smooth,but there are swirl marks in it.I have tried various products to get them out,including 3m Finesse,but to no avail.
Don't have much body work experience,so my question is whats the best way to get a nice finish? Thanks in advance for any suggestions....
Old May 12, 2009 | 08:12 PM
Wet sand and then use rubbing compound. Finish up with a fine polish/swirl remover. Did the painter clear it?
Old May 13, 2009 | 12:29 AM
Circuit_Burner's Avatar
guru of things sparky
A lot depends on what kind of clear coat he used.
I used Omni clear urethane. If theres scratches or stuff like that I break out 2000 grit sand paper. Then polish it shiny with mcguire's (sp) mirror glaze junk.
Old May 13, 2009 | 03:32 AM
Billzilla15's Avatar
if he used a clear coat it will most likely need to be buffed again... i do body work for a living and when we buff a customers car we first wet sand with 1500 grit then use 3,000 grit on a DA sander, buff it with a coarse rubbing compound followed by polishing it with with a finer polishing compound both on a buffer
heres what we use
http://www.farecla.com/automotive-products.html
we use the G3 as the rough cut and the G10 as the finishing polish
this stuff is nice because unlike the 3M stuff, this is used with water to keep the paint cool and gives you way less of a chance to burn through
after polishing it with the machine it's nice to hand polish it with somithing like thishttp://www.afterthoughtsauto.com/racglazpolse.html
make sure its a polish or a sealer, DO NOT USE A WAX for at least 1 month after having it painted, the paint is not cured yet.
hopefully this helped
Old May 15, 2009 | 10:42 AM
steve.g's Avatar
No,he did not clear coat....
So wet sand with 1500 grit,then 3000 grit and buff. Thanks guys......
Old May 15, 2009 | 11:30 AM
watch your edges on the panels burning through will be SUPER EASY!!! if you're not careful
if theres just swirl marks in the single stage i would just buff it no need to wetsand again
Old May 15, 2009 | 11:37 AM
steve.g's Avatar
10-4.... Thanks!
archaicguy
Feb 13, 2012 03:18 PM
saxman
May 22, 2007 10:07 PM
vtrlvr
Feb 12, 2007 05:16 AM
joshn569
Feb 6, 2007 07:39 PM
Dave Wicks
Nov 17, 2006 07:21 PM
