Muffler hangers without footpegs
Old Aug 22, 2016 | 06:13 AM
wfoerk's Avatar
wfoerk is on a distinguished road
Does anyone know where I can get aftermarket exhaust hangers without footpegs?
thanks-
Old Aug 22, 2016 | 10:55 AM
Google "superhawk exhaust hangers" and the top left picture is a pair from Projection Racing. Also "firestorm exhaust hangers" on ebay.co.uk and there are at least 2 different pairs for sale there. That took about 30 seconds so if you search around I'm sure you can find more options.
Old Aug 22, 2016 | 06:34 PM
wfoerk's Avatar
Well sir, yes, I have heard of this Google thing. In fact I used it extensively before coming to the forum with my question. All I've found, and all of what you've mentioned, are for high mount cans. Mine are low mount. Thanks for your time.
Old Aug 22, 2016 | 11:50 PM
Actually wasn't trying to be a wiseass. Just did a quick search for you and was saying I'm sure you can find more if you keep looking. Those ARE "aftermarket exhaust hangers without footpegs," you didn't specify high or low. BUT, if you're looking to eliminate your passenger pegs those will work fine. Standard mount midpipes will rotate up enough to work with those (they may be for "high" but not "ultra high" like LeoVince or Devil) and also give you a cool "low to high" look like an RC51. I and several others have done it before.
Old Aug 22, 2016 | 11:53 PM
And by the way I took another look at the ones on ebay.co.uk and those both appear to be standard mount brackets.
Another free option I've also seen done would be to simply remove the footpegs and cut off the brackets that held them. A little grinding and some sanding and polishing will finish them off. So you'd have the stock hangers just minus the footpegs.
Old Aug 23, 2016 | 09:20 AM
I have a set of said Projection Component low-mount hangers (have been powdercoated black) that I am looking to part with. If interested drop me a line.
Old Aug 24, 2016 | 01:33 AM
I have projection high mount hangers and with a bit if fiddling they fit.
Have been on the bike for a few years now with no problems.
Here's how they look .
Hope this helps.
Old Aug 24, 2016 | 07:47 PM
Hope this helps.
Don't mean to be rude or burst any bubbles, but from what I can tell those are the standard/low mounts (only ones made by PC; ie. identical to mine).
Old Aug 25, 2016 | 02:04 AM
Funny you say that,
I was worried when I bought them from the dreaded flea bay as they were listed by projection as high mount and I was thinking that because I had just ordered a new set of cans and link pipes that I was going to have to do some major mods to get them to fit.
I did have to fiddle a bit but got it all to work. I took the measurements from the standards as compared to what I now have and from memory the cans were about 3 " higher and located closer to the bike.
Here is another view from the rear that accentuates the difference over standard . Sorry it's on an angle as my rear stand is under another bike at the moment.
[URL=http://s1000.photobucket.com/user/kbarr2/media/Mobile%20Uploads/2016-08/8FEBC9D5-B158-4C16-9DF7-ADD90D24999F_zps24u5xtuk.jpg.html]Name:  8FEBC9D5-B158-4C16-9DF7-ADD90D24999F_zps24u5xtuk.jpg
Sorry it's a bit dark in the man cave at the moment but you should get the idea. The distance from the rear cowl to the can is somewhat diminished.
If you can't see that here is a pic of a standard VTR.
Granted they are not as high as some but they are higher than standard.
It's not a bother to me as I prefer the more traditional look rather than the really high mounts like staintune etc.
Old Aug 25, 2016 | 02:10 AM
Better shot from a distance, notice how you can clearly see the rear disc and caliper whereas on the standard bike you can't.
The bike on the right definitely has high mounts eh!
Old Aug 25, 2016 | 06:03 AM
erno's Avatar
erno
Have a go and make em yourself ,not hard did mine using mild steel and then getting it chrome plated
Old Aug 24, 2017 | 05:45 PM
AlanS's Avatar
VTR1000F ALL YEARS LADYBIRD JAPAN HAND BENT ALUMINIUM EXHUAST HANGERS | eBay
I bought a set of these.
Alan
Old Aug 24, 2017 | 08:10 PM
Originally Posted by AlanS
He sells the most beautiful stuff... The full exhausts he sells are absolute works of art.
Old Aug 25, 2017 | 03:56 AM
He does do great stuff !
Funny name though.
Unfortunately my pockets aren't that deep at the mo but I would like a set of those hangers.
Maybe one day !
Old Aug 25, 2017 | 06:35 AM
bought a few items from Simon over the years, including the HRC ignition box (which he found for me) as well as the famed Zcoo brake pads (which Ken now has). Great guy to deal with.....
inderocker
Feb 29, 2008 08:57 AM
TommyboyinMI
May 2, 2007 08:04 AM
Radiaoktiv
Nov 19, 2006 10:14 AM
lifeofadvntr
Jun 12, 2006 08:49 AM
mick
Apr 30, 2006 10:30 AM
