LP rear turn signals blinking fast
Old Mar 31, 2009 | 09:05 AM
Dnagmour's Avatar
Dnagmour is on a distinguished road
I have flush mounts on the front (dont know who made them) and had stock signals on the back. Bought LP short stalk signals for the back and the litle wiring adapter so they plug in. Now all of my signals blink fast. They arent LED's or anything. What is causing them to blink fast?
Old Mar 31, 2009 | 09:12 AM
They are a different wattage than the stock bulbs.
Old Mar 31, 2009 | 09:17 AM
Dnagmour's Avatar
So what is the best way to slow down the blinking?
Old Mar 31, 2009 | 09:20 AM
http://www.cyclegear.com/spgm.cfm?L1...tem=MRX_FRU1_G
Old Mar 31, 2009 | 09:49 AM
Dnagmour's Avatar
Thanks! Although I think thats more than I paid for the signals
Old Mar 31, 2009 | 10:01 AM
Billzilla15's Avatar
check out these guys i have their flasher on my bike with all leds and it works great
http://www.customdynamics.com/trick_flasher.htm
cheap and fast shipping
Old Mar 31, 2009 | 10:33 AM
Dnagmour's Avatar
Thanks, I'll check 'em out. If I'd have known the'd blink fast I'd have bought LED's!
Old Mar 31, 2009 | 10:35 AM
haknslash's Avatar
Load equalizers are also available at your local Advanced Auto for much cheaper ($12 http://shop.advanceautoparts.com/web...CGRP2044__load___). I had them in mine. They usually carry them in stock where all the LED/Neon stuff is.
Old Mar 31, 2009 | 10:53 AM
maverick's Avatar
-Your flasher is nothing more than a bimetallic strip between two contacts. Current flows through this strip on its way to the turn signal, and when too much current passes through, the strip warps up and breaks the contact momentarily because the inside of the strip expands more quickly with heat. It cools and returns. If you are blinking too fast, too much current is flowing through. You don't need to buy anything more than a few resistors from radioshack and wire them in series with each blinker. Just measure the resistance of your old light, and your new one, find the difference, and go buy that resistor. Should get you back to normal. And shouldn't cost more than a buck or two at most.
Old Mar 31, 2009 | 11:04 AM
Dnagmour's Avatar
Man I love this forum! Thanks to everyone. I appreciate the help.
Old Apr 1, 2009 | 09:30 AM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
Before you go any farther, check all your signal connections. I had an issue with fast blinking and traced it to rear signal where a wire had broken inside the signal housing - re-soldered and it was fine.
Old Apr 1, 2009 | 10:13 AM
Erik S.'s Avatar
just let them blink fast. Should help you be seen a little better.
Old Apr 1, 2009 | 11:54 AM
Dnagmour's Avatar
I'll check the connections tonight. Maybe I'm color blind or something
DaNewKidd
Jun 30, 2010 02:52 PM
johnclopp85
May 13, 2009 07:20 AM
marmaladedad
Apr 24, 2006 07:37 PM
cb21983
Mar 21, 2006 05:59 PM
