Input wanted please
Old Feb 17, 2007 | 11:54 PM
Input wanted please
Hi folks,
as I have just purchased a set of bar-end mirrors for my beloved VTR, I will be removing the old mirrors. AS I think it is now time to ditch the OEM front turn signals for someting a bit sportier and streamlined, I was thinking of trying the following: run small (always on) running lights flush mount in the current signal hole, and try to hook up another set of miniature (bright) lights in the old mirror holes for the flashers. I only need to split the ground and sire up the two circuits, that should be easy. QUestion about the type of lights to use as I am told some are prone to overheating (mostly a concern for the running lights). Comments/suggestions welcomed
cheers
Old Feb 18, 2007 | 01:25 AM
shayne's Avatar
Interesting idea.
I would suggest led's would be a good option. Low heat, and last forever.
Old Feb 18, 2007 | 06:29 AM
jschmidt's Avatar
jschmidt
Just be sure to use a directional setup (like leds) Having lights that close to your head could significantly impair your field of vision.
Old Feb 18, 2007 | 08:01 AM
thakks Jim (and Shayne),
I was thinking exactly that. With LED's would I need an additional resistor for the signals?
cheers
Old Feb 18, 2007 | 08:02 AM
iamanonymous's Avatar
iamanonymous is on a distinguished road
cheers
yes
Old Feb 18, 2007 | 10:04 PM
shayne's Avatar
Hmm........ I am not sure if I have misunderstood what you are up to exactly with your wiring.
I would power your running lights from your headlight/tailight circuit and run led's in them. No resistor necessary. You can put an led in the parking light as well and it has no effect.
For the blinkers you can run a normal globe, and then you won't need the resistor, unless you run low wattage globes.
Old Feb 18, 2007 | 11:37 PM
jschmidt's Avatar
jschmidt
cheers
No. A resistor is absolutely the worst way to solve this problem. What you need to do is swap in a flasher module that doesn't have burn out detection. Flashers with this feature -- like the stock one -- will flash fast when they think a bulb is out. But ones that don't can be had for $5 or so.
Old Feb 19, 2007 | 06:13 AM
thanks again
redsuperhawk
Oct 2, 2006 04:25 PM
ziz
Sep 12, 2006 10:14 PM
cdsgrafix
Aug 22, 2006 06:21 PM
ziz
Aug 19, 2006 01:05 AM
mikecronis
May 21, 2006 09:49 AM
