Front Signals
Old Mar 18, 2007 | 09:01 PM
Dave Wicks's Avatar
Dave Wicks is on a distinguished road
Front Signals
I need to replace my front signals. One is drooping as a result of a "tip" over. I'm going to use flush mounts. What is the simplest and best signal to use??
I wait to heat from your collective wisdom... thanks.. oh and yes I have checked the threads.. still seeking info
Take Care
Dave....
Old Mar 18, 2007 | 11:46 PM
Well Dave, this "drooping" problem sounds more personal than I wish to discuss openly on the forum with you. I'll PM you with my doctor's contact info. He's probably going to suggest a little blue pill for you. Hope the wife's taking it okay.
No, seriously this depends on how squidly you want to be. Are you one of those "safe" guys looking for maximum conspicuity or would you like to go with some flush mounts which are not as visible? I think your conspicuous options are limited to stock and very few aftermarket stalk-type signals just because the fairing holes are so damned large. LEDs are bright but will require additional electronics to act as running lights (www.vfxkits.com). The flush mounts I have are LP type IVs IIRC. I just posted up yesterday on the required modification of these to fit. I'll see if I can get you a link, sir.
Old Mar 18, 2007 | 11:50 PM
Here you go, brother: https://www.superhawkforum.com/forum...4907#post44907
Robin427
Mar 16, 2012 02:50 PM
Robin427
Mar 16, 2012 01:18 AM
johnclopp85
May 13, 2009 07:20 AM
snowman666
Apr 17, 2007 06:58 AM
