Anyone try painting the little engine cover?
Old Oct 10, 2011 | 11:12 AM
blamecanada's Avatar
blamecanada is on a distinguished road
...to match the rest of the bike's body work?
how dumb would it look?
Old Oct 10, 2011 | 01:04 PM
CrankenFine's Avatar
If by "little engine cover" you mean the plastic piece over the oil filter, I have seen a photo of a red one here recently where it was painted to match the rest of the bodywork. I think it looked very good and I am considering doing the same.
Old Oct 10, 2011 | 01:37 PM
mertechperformance's Avatar
MandownMertech
or did ya mean the valve covers?
Old Oct 10, 2011 | 01:43 PM
Wicky's Avatar
or clutch / alternator covers?
Old Oct 10, 2011 | 02:33 PM
ahhh sorry, yes I can see that "little engine cover" is not a very accurate way to describe what I was referring to - which is indeed the oil filter cover.
I've been pondering getting some base/clear dupli-color paint and trying to match it to the bodywork
Old Oct 14, 2011 | 09:17 AM
MOONSTER's Avatar
I've painted my several times, this is the latest version.
Attached Thumbnails Anyone try painting the little engine cover?-dscn0634.jpg
Old Oct 14, 2011 | 10:05 AM
Thumbs up
I like it.
Old Oct 14, 2011 | 02:14 PM
comedo's Avatar
Sometimes it's called a chin fairing but "a rose by any name" etc.
Old Oct 14, 2011 | 08:29 PM
dehning's Avatar
dehning is on a distinguished road
When I was talking to the guy I bought my Chinese fairings from, he asked me if I wanted that little piece painted the stock silver color or the same blue as the rest of the bike. I did mockups in photoshop and in the end I decided that it didn't look good being the same color as the rest of the bike, it looks like it's kind of just stuck on there with no purpose. When it's silver I think it helps to separate it from the main bodywork. Now for a lower full cowl, I'd say matching colors are a must.
Old Oct 14, 2011 | 09:12 PM
racer187x's Avatar
racer187x is on a distinguished road
Mine was painted by the previous owner to match. I like it better than that grey that came stock.
Old Oct 14, 2011 | 09:39 PM
broncsrule21's Avatar
broncsrule21 is on a distinguished road
I think matching the other plastics looks good. But I would be afraid that I couldn't match my yellow exactly. Is there a paint code available?
Old Jan 5, 2012 | 09:03 PM
zxbud's Avatar
Fairing
Could you post some closeup pics of your Chinese fairing pieces? They look good in the ads and I can't tell how they appear mounted. What's you opinion over all?
Old Jan 5, 2012 | 10:48 PM
thetophatflash's Avatar
I used Ducati red on the chin fairing, rear light and radiator grills and Ducati Midnight black for the rear fender, chain guard and license holder.
Old Jan 6, 2012 | 10:13 PM
poppazuti's Avatar
Head Scratcher
You should have a paint code for it on the subframe, behind the tail fairing. There were two versions of the yellow (pearl and flash I believe used for different model years).
Any body-shop should be able to pull the mixture codes for you and you can have it mixed at Napa for around $30 (in aerosol cans, possibly cheaper if you just buy the quart).
The color has probably faded quite a bit, but since the chin fairing doesn't reside anywhere near the rest of the body work I don't think the difference would be noticeable to the naked eye.
Old Feb 15, 2012 | 06:01 PM
102dals's Avatar
I thought most people just took them off & threw them away? Just kidding, but mine is off for the trackdays.
Old Feb 15, 2012 | 06:11 PM
1971allchaos's Avatar
If you remove the seat from the bike.. On the sub-frame rails that the undertail is supported by.. There should be a white tag, with black letters.. Should be-- Y124P , which is Honda's "Pearl Shining Yellow".. If your bike is still OEM paint..
Old Feb 15, 2012 | 08:03 PM
As long as it's the stock color you can get it from colorrite.com. As was stated your paint code is on a decal on your subframe. In your case stock yellow is Y124P "pearl shining yellow."
Paint Search :: Color Results - ColorRite
I had a bodyshop match up the stock yellow on a '99 I rebuilt and for pretty cheap they painted both side fairings and the tail to match a stock tank, headlight fairing, and solo seat cover, and it was at least a 95% match. It's a hard color to get perfect with the pearl & all but you can't tell from the pictures. But I wouldn't be so concerned about the match if you're just painting the chin cowl-it doesn't butt up against anything else where you're going to notice a tiny shade difference.
CrickiKaze
Mar 19, 2014 12:06 AM
swaptrex
Mar 24, 2010 02:12 PM
Pimpsterbim1
Aug 17, 2009 05:45 PM
klicks
Oct 25, 2006 10:56 AM
mikstr
Jun 2, 2006 07:02 AM
