Anyone take the stock taillights apart?
Old May 7, 2006 | 02:56 PM
bluevtr's Avatar
bluevtr
Was out in the garage looking at the bike last night, trying to figure out how to get rid of that vast expanse of plastic, and began to wonder...
It looks like the stock taillight may possibly have a red lens over clear on the bottom side. If that's true, taking or cutting the red from that area would allow light to shine out the bottom, then the tag mount could be moved up to where the reflector is now, and there'd be no need for the tag light. Does anyone know if this would work? Or maybe a section could be cut out of the bottom, and a small window of clear acrylic put in it's place?
Also, regarding cutting the rear plastic, do you recommend a reciprocating saw over a dremel tool? Seems like it would be easier to control with less "jumping around".
Old May 7, 2006 | 05:47 PM
Corona Hawk's Avatar
Corona Hawk is an unknown quantity at this point
Re: Anyone take the stock taillights apart?
You can drill holes on the bottom of the lens cover. It is also recommended that you use a dremel to cut the lower part of the fender.
Old May 7, 2006 | 06:49 PM
bluevtr's Avatar
bluevtr
Cool, thanks. If you have done this, do you have any problems with dirt getting up inside the housing, or did you cover the holes with something clear?
Old May 7, 2006 | 07:34 PM
jschmidt's Avatar
jschmidt
Just find a piece of clear plastic and glue it on.
Old May 7, 2006 | 07:41 PM
bluevtr's Avatar
bluevtr
I like it. I think I know what I'm doing on Wednesday now....
Old May 8, 2006 | 06:24 AM
Pdaddy's Avatar
Pdaddy
I cut my rear fender off yesterday. I used a pnuematic angle grinder and covered up everything with a towel. You can cut straight and fast but it "strings" the plastic from heat and what not a bit.
Twitch78
Sep 3, 2012 10:12 PM
GTS
Apr 21, 2012 04:26 PM
5150
Aug 16, 2010 09:08 PM
Gritsngravy
Jun 14, 2009 02:56 PM
HisHawkiness
May 5, 2009 07:39 AM
