Now What?
Now What?
6 years in and running out of things to do to my favorite ride. Other than engine internal mods, I think I've done everything I need/can do to my SH. Thanks to this forum, Eric, Jamie, Beau, Mike, and many others I have the perfect (for me). I've done suspension, brakes, clutch, shifting, intake/jetting, flywheel, 19 liter tank, COP, R/R, MCCT's, Lots of aesthetic and comfort mods,
on and on and on! It runs perfect.
Looks awesome. And if it's perfect for you then I would leave it alone and enjoy it. Maybe find a different project or even another Superhawk project. Is there more you could do? Sure. I put a bike together years ago with an SP2 front end, radial brakes, Marchesinis, SP2 swingarm, Ohlins shock, Gilles rearsets, etc, etc etc... But there's no end to that and for many it eventually can become more of a hassle than it's worth. It did for me. My 2 cents anyway...
You have the same version of OCMD that I suffer from! I was just looking at a larger oil cooler. Not needed but "need" plays no role in OCMD. Where did you find the adaptive fittings?
They are hard to come by and you need a remote mount petcock. I got mine from Australia (Bike Spares Australia) It had to be labeled "Body parts" or US customs will reject it.
The extra 3 Liters (3/4+ gals) really helps. Due to the slight reshaping bottom of the tank, I've gained about another 10 miles after the YLOD comes on before I'm pushing. LOL The way I ride I get about 125 miles out of my 19L tank. By then my 65 year old butt is ready for a break anyways.
Thanks, here's the list; Engine: Marquez Racing-lightened flywheel, Anti-rattle gear removed, ETL-MCCTs, TBR Head pipes, Yosh. RS3 slip-ons, Dellwood-velocity stacks, Jetted (HRC guidelines and dynode) K&N filter (modded w/dam), FP +4 Ign. advancer, TPS @500 ohms, De-PAIRed, Marquez Racing COP cables w/CBR 1000 coils, Oberon Clutch slave w/speed bleeder, Honda VFR 14mm Clutch master w/speed bleeder, Galfer S.S. clutch line, Coerce sprocket guard/slave mount, FP shift star and detent, DMR shifter. Brakes: Front; Galfer wave rotors, Galfer S.S. lines, Tokico 6 piston calipers (2002 Suz. GSXR) w/speed bleeders, EBC HH pads, Nissin 15.87 mm Master cyl. (2001 Suz. GSXR) speed bleeder @ banjo bolt, Rear: Galfer wave rotor, Galfer S.S. line w/speed bleeder, EBC HH pad. Suspension: Frt; DMR Cartridges, Race Tech 95 kgm Springs, SKF seals and wipers, Steering stem; All ***** tapered roller bearings, Coerce fork brace. Rear; DMR re-valved,-re-sprung OEM. Electrical; Deltrans LiFe Battery, Marquez MOSFET R/R setup, Cyclops Ultra 10.0 LED headlight, Proton Frt. & Rear Signals, Complete LED change out gauges, Etc, Honda Euro Flash to Pass headlight and Bypass to start switching, Honda Euro wiring mods, 12o'clock Labs speedo calibrator. Comfort/convenience; Corbin seat, Zero Gravity Double bubble wind screen, Vista Cruise throttle lock, Honda 19 Liter fuel tank, Vortex vV2 levers w/needle bearing pivots, ODI race grips, Oberon pegs. Aesthetics; Coerce Carbon fiber front fender and rear hugger, A-Tech Carbon fiber chin spoiler, Power Bronze Under Tail, Sport Fairings Castrol fairing set, Billet red clutch reservoir, rear brake reservoir caps, Rizoma red frt. brake reservoir, red titanium Steering stem nut, Billet red (Honda) bar end weights, Billet red stator and timing plugs, Strada windscreen fasteners, Lady Bird pipe hangers, Pro Bolt red billt oil filler cap.
Now Erics got me obsessed with a new/bigger oil cooler and S.S. supply lines! So much for my next Social Security check! OCMD has struck again!
UH OH! I just found the ProBolt site! They have Titanium EVERYTHING for Super Hawks for about $1200 shipped I could replace all the engine case, suspension, and brake bolts plus the axle nuts and swing arm pivot nuts. Heck that's only about $150 an once in weight savings! I don't really need food and clothing anyways!
Some have wired the Euro switch to the existing wiring with success. I chose to follow the Euro wiring diagram which entailed running an additional wire thru the loom and tapping into the harness under the seat, behind the battery, ala factory. But, I'm old, **** and I've got nothing else to do. I think E. Marquez did a post about using the existing harness. Search
I think I located a couple of different oil coolers, w/lines and adapters from Webike Japan. I'm working on a braced swingarm. I just need to find a carbon fiber hugger to fit.
EDIT: Found it, was in the HID projector light thread https://www.superhawkforum.com/forum...-lights-32695/
Pidge, I'm rolling my quarters for my wheel fund. I know where there's a set of new Gale Speeds for sale but the guy wants serious coin. On the positive side they're fitted with discs and sprocket carriers already and he's in no hurry.
I looked into doing this years ago and found that the oem Honda fittings are very unique. And you almost have to adapt them to the hose which is not easy.
I found no suitable fittings without modifying the engine case by drilling and tapping it out for a standard fitting
