Now What?
Old Dec 15, 2019 | 10:46 PM
CaryDG's Avatar
Now What?
6 years in and running out of things to do to my favorite ride. Other than engine internal mods, I think I've done everything I need/can do to my SH. Thanks to this forum, Eric, Jamie, Beau, Mike, and many others I have the perfect (for me). I've done suspension, brakes, clutch, shifting, intake/jetting, flywheel, 19 liter tank, COP, R/R, MCCT's, Lots of aesthetic and comfort mods,
on and on and on! It runs perfect.
Old Dec 16, 2019 | 03:38 PM
Looks awesome. And if it's perfect for you then I would leave it alone and enjoy it. Maybe find a different project or even another Superhawk project. Is there more you could do? Sure. I put a bike together years ago with an SP2 front end, radial brakes, Marchesinis, SP2 swingarm, Ohlins shock, Gilles rearsets, etc, etc etc... But there's no end to that and for many it eventually can become more of a hassle than it's worth. It did for me. My 2 cents anyway...
Old Dec 16, 2019 | 04:22 PM
I second the captain.
"...perfect (for me)"
You're done until something isn't perfect. Which will come. OCMD.
Old Dec 17, 2019 | 05:48 AM
Now What?
Now What?[/QUOTE]
[QUOTE]
Well I see icky oil lines on there
Old Dec 17, 2019 | 09:38 AM
CaryDG's Avatar
You have the same version of OCMD that I suffer from! I was just looking at a larger oil cooler. Not needed but "need" plays no role in OCMD. Where did you find the adaptive fittings?
Old Dec 17, 2019 | 10:04 AM
I made them
Old Dec 19, 2019 | 05:48 AM
While you have done a lot, the bike looks well sorted. I would kill for a 19l tank.
Old Dec 19, 2019 | 10:22 AM
CaryDG's Avatar
They are hard to come by and you need a remote mount petcock. I got mine from Australia (Bike Spares Australia) It had to be labeled "Body parts" or US customs will reject it.
Old Dec 19, 2019 | 10:58 AM
CaryDG's Avatar
The extra 3 Liters (3/4+ gals) really helps. Due to the slight reshaping bottom of the tank, I've gained about another 10 miles after the YLOD comes on before I'm pushing. LOL The way I ride I get about 125 miles out of my 19L tank. By then my 65 year old butt is ready for a break anyways.
Old Dec 19, 2019 | 03:21 PM
fabiostar's Avatar
tidy well sorted looking storm..
Old Dec 19, 2019 | 05:24 PM
CaryDG's Avatar
Thanks, here's the list; Engine: Marquez Racing-lightened flywheel, Anti-rattle gear removed, ETL-MCCTs, TBR Head pipes, Yosh. RS3 slip-ons, Dellwood-velocity stacks, Jetted (HRC guidelines and dynode) K&N filter (modded w/dam), FP +4 Ign. advancer, TPS @500 ohms, De-PAIRed, Marquez Racing COP cables w/CBR 1000 coils, Oberon Clutch slave w/speed bleeder, Honda VFR 14mm Clutch master w/speed bleeder, Galfer S.S. clutch line, Coerce sprocket guard/slave mount, FP shift star and detent, DMR shifter. Brakes: Front; Galfer wave rotors, Galfer S.S. lines, Tokico 6 piston calipers (2002 Suz. GSXR) w/speed bleeders, EBC HH pads, Nissin 15.87 mm Master cyl. (2001 Suz. GSXR) speed bleeder @ banjo bolt, Rear: Galfer wave rotor, Galfer S.S. line w/speed bleeder, EBC HH pad. Suspension: Frt; DMR Cartridges, Race Tech 95 kgm Springs, SKF seals and wipers, Steering stem; All ***** tapered roller bearings, Coerce fork brace. Rear; DMR re-valved,-re-sprung OEM. Electrical; Deltrans LiFe Battery, Marquez MOSFET R/R setup, Cyclops Ultra 10.0 LED headlight, Proton Frt. & Rear Signals, Complete LED change out gauges, Etc, Honda Euro Flash to Pass headlight and Bypass to start switching, Honda Euro wiring mods, 12o'clock Labs speedo calibrator. Comfort/convenience; Corbin seat, Zero Gravity Double bubble wind screen, Vista Cruise throttle lock, Honda 19 Liter fuel tank, Vortex vV2 levers w/needle bearing pivots, ODI race grips, Oberon pegs. Aesthetics; Coerce Carbon fiber front fender and rear hugger, A-Tech Carbon fiber chin spoiler, Power Bronze Under Tail, Sport Fairings Castrol fairing set, Billet red clutch reservoir, rear brake reservoir caps, Rizoma red frt. brake reservoir, red titanium Steering stem nut, Billet red (Honda) bar end weights, Billet red stator and timing plugs, Strada windscreen fasteners, Lady Bird pipe hangers, Pro Bolt red billt oil filler cap.
Now Erics got me obsessed with a new/bigger oil cooler and S.S. supply lines! So much for my next Social Security check! OCMD has struck again!
Old Dec 19, 2019 | 05:31 PM
CaryDG's Avatar
UH OH! I just found the ProBolt site! They have Titanium EVERYTHING for Super Hawks for about $1200 shipped I could replace all the engine case, suspension, and brake bolts plus the axle nuts and swing arm pivot nuts. Heck that's only about $150 an once in weight savings! I don't really need food and clothing anyways!
Old Dec 19, 2019 | 07:04 PM
CaryDG's Avatar
Recalculating! More like $150 per gram!
Old Dec 19, 2019 | 09:08 PM
"Perfect for me..." Yeah, right.
Old Dec 19, 2019 | 11:44 PM
CaryDG's Avatar
HELP ME MR. WIZARD! I've got OCMD, but at least I'm happy with my tires and oil.
Old Dec 20, 2019 | 06:26 AM
And you know what I just found..... a spare set of weld on AN adapters and OEM motor side oil line fittings sitting in a box...lonely, all alone this Christmas, needing to be warm and wanted.
Old Dec 21, 2019 | 09:27 AM
CaryDG's Avatar
$? Pics?
Old Dec 21, 2019 | 01:53 PM
$? Pics?
looks like I have parts for two sets of engine side adapters and one set of OEM cooler side adapters
Old Dec 27, 2019 | 08:07 AM
fabiostar's Avatar
you need a braced swingarm, well you dont NEED it but its something to do
Old Dec 27, 2019 | 09:35 AM
cpl rampage's Avatar
cpl rampage is on a distinguished road
Quite the list there. I am interested in the flash to pass switch and honda euro wiring mods. Was the switch a drop in or was that what the wiring mods were for?
Old Dec 27, 2019 | 05:01 PM
CaryDG's Avatar
Some have wired the Euro switch to the existing wiring with success. I chose to follow the Euro wiring diagram which entailed running an additional wire thru the loom and tapping into the harness under the seat, behind the battery, ala factory. But, I'm old, **** and I've got nothing else to do. I think E. Marquez did a post about using the existing harness. Search
Old Dec 27, 2019 | 05:06 PM
CaryDG's Avatar
I think I located a couple of different oil coolers, w/lines and adapters from Webike Japan. I'm working on a braced swingarm. I just need to find a carbon fiber hugger to fit.
Old Dec 27, 2019 | 05:40 PM
I did someplace...it was "easyish" ..confirm all pins/circuit/functions of old and new switch, depin and repin connector, have at it.
EDIT: Found it, was in the HID projector light thread https://www.superhawkforum.com/forum...-lights-32695/
Old Dec 28, 2019 | 03:19 AM
Pidge's Avatar
I really like what you have done with the bike. She is a beauty. How you can stand the stock wheels is beyond my ken though.
Old Dec 28, 2019 | 06:34 AM
JamieDaugherty's Avatar
Glad you are happy with your bike. It looks great!
Old Dec 28, 2019 | 09:19 AM
CaryDG's Avatar
Jamie, Thanks to your suspension work, she rides like a dream!
Old Dec 28, 2019 | 09:36 AM
CaryDG's Avatar
Pidge, I'm rolling my quarters for my wheel fund. I know where there's a set of new Gale Speeds for sale but the guy wants serious coin. On the positive side they're fitted with discs and sprocket carriers already and he's in no hurry.
Old Jun 27, 2023 | 04:09 AM
Mallebollia's Avatar
Mallebollia is on a distinguished road
Now What?
Well, I need someone who can make me those lines with the adaptive fittings. Any ideas?
Old Jun 28, 2023 | 05:01 PM
I'd think a good hot-rod shop could do that for you.
Old Jun 28, 2023 | 05:53 PM
I looked into doing this years ago and found that the oem Honda fittings are very unique. And you almost have to adapt them to the hose which is not easy.
I found no suitable fittings without modifying the engine case by drilling and tapping it out for a standard fitting
