‘04 Going Naked
Old Apr 15, 2024 | 08:23 PM
  #31
Squid's Avatar
Originally Posted by Bald Eagle
I am assuming the holes will be how the hot air from the radiator will be escaping.....?
Will the fan be attached to the radiator facing the holes.?
I see no issues with your glass work.....kind of clever to fiber glass the two pieces together.
you are correct. I do not have the fan. It was broken from the PO when he laid it down. Will have the fan mounted on top of the rad to pull up and push out thru the holes.
thank you, first time Messing with the stuff and I’m pretty happy with it. Not flawless but I’m no pro. I also cut out the overlap of the tail section where the cowl sit to prevent any area that would disrupt airflow.
Old Apr 25, 2024 | 07:01 AM
  #32
Bald Eagle's Avatar
Bald Eagle is on a distinguished road
I have an additional fan if you need one. It is stock style fan ..... I'll have to dig it up (find it), with the blades reversed so you are pulling the cool air out through, what was the wife's seating area.....
Not sure if you should upgrade to a more powerful unit though.....since you will be having to make your own brackets for the Radiator.
Old Apr 25, 2024 | 11:58 AM
  #33
Squid's Avatar
im not too sure on what I will be doing as far as a fan goes for now. If I need it I’ll it you up. I’m still trying to get it running right.
Old Apr 25, 2024 | 12:02 PM
  #34
Squid's Avatar
Carb tuning is now a priority. But after that all that is needed is todo is mount the brake light, turn signals on both ends, and make a rear brake stay for the underslung caliper.
Old May 6, 2024 | 12:20 PM
  #35
Squid's Avatar
Rear brake mounting
Mocked up for now till I can find someone to weld in the front caliper mount stay.
Old May 8, 2024 | 08:13 AM
  #36
Tripleplay707's Avatar
Tripleplay707 is on a distinguished road
helluva ride!!!
can we get some vids????
Old May 8, 2024 | 11:39 AM
  #37
Squid's Avatar
Originally Posted by Tripleplay707
helluva ride!!!
I’ll do a walk around vid this weekend and a sound clip.
Old May 10, 2024 | 05:52 PM
  #38
Squid's Avatar
Walk around video
Here is it, 90% complete.
https://youtu.be/_dvRbg77LpE?feature=shared
Old May 11, 2024 | 06:48 PM
  #39
Wow
Helluva ride...
Amazing build!
I applaud you!!!
VTRDarren
May 14, 2022 04:04 PM
CrankenFine
Nov 11, 2020 07:35 PM
Wolverine
Jul 31, 2008 06:30 PM
gboezio
Sep 12, 2007 04:32 PM
