‘04 Going Naked
Long story short. 4 years ago sold the bike, got it back for $300 four months later from impound after the guy went on a high speed chase with it and laid it down. Took a hiatus dude to back issues and now over the past 2 months have been getting it to where I’ve always wanted it. It’s not going to be everyone’s cut of tea or pint of beer but oh well this is what I like.
“Upgrades” are as follows: ‘02 RC51 front end re-valved and sprung, Core steel braided brake lines, brembo radial MCs, braced swinger, CBR900rr rear wheel, motogadget M Unit Blue, M Button (in the right clip-on) aftermarket Amazon momentary switches, custom harness, LED 5 1/2” round head light, under tail radiator, Moriwaki rear sets. It’s a work in progress but hope to have it running in the next 2-3 weeks. https://cimg0.ibsrv.net/gimg/www.sup...7dce61c20.jpeg https://cimg1.ibsrv.net/gimg/www.sup...23dd68186.jpeg https://cimg3.ibsrv.net/gimg/www.sup...612728b0a.jpeg https://cimg4.ibsrv.net/gimg/www.sup...def16689a.jpeg https://cimg5.ibsrv.net/gimg/www.sup...eeed52e13.jpeg https://cimg7.ibsrv.net/gimg/www.sup...70d02b61e.jpeg https://cimg0.ibsrv.net/gimg/www.sup...a8590464a.jpeg https://cimg4.ibsrv.net/gimg/www.sup...fa24348cd.jpeg https://cimg5.ibsrv.net/gimg/www.sup...8a8aea4f5.jpeg https://cimg7.ibsrv.net/gimg/www.sup...6d17e0e36.jpeg https://cimg8.ibsrv.net/gimg/www.sup...50d68497c.jpeg https://cimg9.ibsrv.net/gimg/www.sup...197aedd96.jpeg |
Wow! A lot of time and effort. Like the rear radiator, hope it works out for you. Really cleans up the lines for a naked build.
Is the front wheel from an SP2? If so, super rare. |
Originally Posted by xeris
(Post 416437)
Nice build, keep the pictures coming.
Originally Posted by NHSH
(Post 416447)
It'll be interesting to see whatcha come up with.
I love the idea of the rear radiator...there was someone on this forum who had done it and worked out well for him....but I did try it myself and the bike could not cool down sufficiently to a normal temp. I ended back with the original set up of the two radiators.... which I will try to make look better without the fairing.
https://cimg5.ibsrv.net/gimg/www.sup...f624a49f18.jpg https://cimg8.ibsrv.net/gimg/www.sup...c91c159722.jpg https://cimg0.ibsrv.net/gimg/www.sup...f40bb08566.jpg https://cimg6.ibsrv.net/gimg/www.sup...a3cb3776ca.jpg |
Originally Posted by Bald Eagle
(Post 416467)
I kind of understand what you are saying, but my problem was (after going on the highway) with the setup I had, it would not cool down even with the cooling fan operational. It worked in the garage before I took it out on the street, but the fan could not handle it once I was on the street and probably should have had a bigger fan. I was using the same type of fan that came with the bike....not good enough. With my 3D printer I made an air scoop to try and aid air flow, with no success. It is in one of the pics. I love the fact the radiators are on the sides, because you never get the heat rushing up at you, especially in city traffic. I use to sweat my gnads off with the Triumph Triple I used to have. My next ..... and final project, on my VTR, is to try and make the side radiators look less intrusive.
Final...
Originally Posted by VTR1000F
(Post 416474)
Final...
i get everything else that you said about your previous scenario. Was your fan pushing air down towards the rear tire since I’m not really seeing much for air to exit thru the top on the pics you posted. hoping that with the fan pulling the air up and out thru the vents and with the thermal dynamics that it will do a bit better on the cooling since it won’t be forced down or around. |
Sorry, replying from my phone and didn’t mean to reply to quote your reply VTR, obviously it was meant for Bald Eagle.
Normally not a huge fan of most "streetfighters" but that's looking really nice so far. Curious, any reason you went with an SP2 front wheel when an SP1 is pretty much a perfect match for the 900RR rear?
(Post 416480)
as well as I hope with the “mods” that I’m doing. As far as the front wheel goes, I found a complete front end from an ‘02 RVT close to me for a decent price with only 12k on it. Eventually I’ll be looking for the least amount of unsprung weight but looking for something to get me by for the time being. |
Slow progress waiting on parts
Some eBay link pipes and shorty “mufflers”. Trying to get this to a point where I can have it ready to run by the 13th for classic motorcycle race at Willow springs as a display at our booth so stock header pipe and aftermarket link and pipe and mufflers will do for now. Found that the PO damaged the Carb Isolators, as well as broke the rear choke nipple that screws into the carb and they won’t be here till the 11th so now I will be working on fiberglass and paint and hope that everything else gets here in time so I can get it running. More pics to follow this weekend, if you all are still interested, or not. Haha
https://cimg8.ibsrv.net/gimg/www.sup...77b563c28.jpeg https://cimg9.ibsrv.net/gimg/www.sup...f3b993b8d.jpeg https://cimg0.ibsrv.net/gimg/www.sup...fa16b5418.jpeg |
Also got the “keyless go” working on the Motogadget so no need for an ignition switch, side stand switch, or clutch switch. Starter cranks, lights light up when on and the alarm activates when I turn off the ignition.
Originally Posted by Squid
(Post 416478)
Riiight. Haha
i get everything else that you said about your previous scenario. Was your fan pushing air down towards the rear tire since I’m not really seeing much for air to exit thru the top on the pics you posted. hoping that with the fan pulling the air up and out thru the vents and with the thermal dynamics that it will do a bit better on the cooling since it won’t be forced down or around. Later. |
The most difficult problem with these bikes is the Carburation. I finally have installed O2 sensors on the down pipes to see exactly how the carbs are working with the engine. Waiting for the weather to get better to come up with the correct settings. It is incredible to see what you think is the "Correct" settings that you installed on the carbs and find out ......Yes.... You are wrong. The beauty of fuel injection you can set up the mapping for any condition / setup that you have made. Stupid things like making sure that your choke cable is all the way in the HOME position.
Later. |
I found the post on the radiator under seat Cafe flat bars...etc..
https://www.superhawkforum.com/forum...tr-7221/page2/ |
(Post 416502)
Sorry for the slow response.....My fan was pushing air down onto the tire, with the idea of scooping air at the bottom of the radiator. The radiator I have is thinner than the one you are installing and I was trying to keep the seat etc the same. Your project is far more involved, which I did not have the time for. I was trying to get away with a "just OK job" and hopefully have a working scenario.....NOT...!!! It did work with a forum member...will have to find his project and forward it to you. I do have Stage II cams...High Compression Pistons...which could be producing much more heat than the standard bike....but works fine with the original radiators.
Later. |
(Post 416503)
Later. |
What I got done today. Just need to get creative on how I’m going to cut them out and not take off too much
https://cimg2.ibsrv.net/gimg/www.sup...013a67eef.jpeg https://cimg3.ibsrv.net/gimg/www.sup...025ee38ec.jpeg |
I noticed with the picture of the battery holder, you had a couple of Pink Stabilizers to be mounted ..... I assume on the rear wheel ....somewhere..?
Also ....where does the Wife sit on the VTR upgrade.....or is that the upgrade :p |
https://cimg1.ibsrv.net/gimg/www.sup...059801b66b.jpg
https://cimg2.ibsrv.net/gimg/www.sup...b872c41ee4.jpg https://cimg3.ibsrv.net/gimg/www.sup...bf50334eba.jpg Photo's of O2 sensors and gauges. Once I feel I have the correct mixture settings I will remove the gauges and O2 sensors, leave the wiring, and have a bracket for my phone. |
(Post 416511)
https://cimg2.ibsrv.net/gimg/www.sup...b872c41ee4.jpg https://cimg3.ibsrv.net/gimg/www.sup...bf50334eba.jpg Photo's of O2 sensors and gauges. Once I feel I have the correct mixture settings I will remove the gauges and O2 sensors, leave the wiring, and have a bracket for my phone. im definitely going to be adding the AFR to mine when I get there. Thanks for the pics! |
Didn’t get to work on the bike as much as I wanted today but managed to get some done. I SUCK at body work / fiberglass / cutting straight lines and corners with tools and my 8 year old son could have done a better job, but I want the “built, not bought” pride in it and can make some adjustments later. Enough of me trying to justify how it looks so far…
More sanding. Ready for primer and paint when the weather gets better. Prepping the tank and fenders tomorrow after work.
I am assuming the holes will be how the hot air from the radiator will be escaping.....?
Will the fan be attached to the radiator facing the holes.? I see no issues with your glass work.....kind of clever to fiber glass the two pieces together. |
