Stator issue???
Stator issue???
So I've tested from leg to leg and I get a reading of 0 ohms all the way across and I'm not seeing a short to ground on any legs but what should my voltage output be??? My bike is getting no voltage back to the battery it seems
Voltage from the rectifier is AC voltage,it is converted to DC by the regulator/rectifier. Under the seat in front of the battery box there is a plug connector where the stator wire connects to the wire harness,mine had melted. I repaired this and that fixed my charging issues.
