Pair Removal Effects
Old May 29, 2008 | 05:17 AM
01-hawkster's Avatar
huh
01-hawkster is on a distinguished road
What exactly does pair removal help. Does the bike run smoother, accelerate better. What are the benefits. I havent removed mine yet and have had my bike for a month and 1/2. Thanks.
Old May 29, 2008 | 05:47 AM
FTMS's Avatar
Two bennifits are you get rid of a lot of pain in the *** hoses and junk under the air box so that you can get to the carbs easier. If you are running aftermarket exhaust it will get rid of the poping on decell that you hear.
Old May 29, 2008 | 01:17 PM
motojoe's Avatar
Sexual Daredevil
Just do it. You'll be glad you did. It wouldn't be a popular mod if it didn't work.
Old May 29, 2008 | 01:19 PM
MarineHawk's Avatar
Well, it won't necessarily eliminate all of the popping you hear on decel, that just comes naturally with bigger twins. It will (unfortunately?) get rid of the vast majority of it. The only reason I wished I hadn't done it was because I thoroughly enjoyed that sound
Old May 29, 2008 | 03:10 PM
It will also make the exhaust run cooler because you won't have combustion occuring there (as much).
Old May 29, 2008 | 03:43 PM
BlackHawk996's Avatar
i support twins
does it do anything besides get rid of hoses and popping haha? better mpg? or anything hell i dont even know what the hell is underneath my fricken gas tank... slaps self on forehead.
Old Jun 2, 2008 | 06:00 AM
haknslash's Avatar
This answers all the questions you need to know https://www.superhawkforum.com/forum...ead.php?t=9875
I plan to do mine when in two weeks when I get back from vacation. Doing a summer overhaul on the bike (flushing coolant and all other fluids, APE CCT install, PAIR removal, wheel adjustment, etc). Should be fun and a chance to learn about the bike since I purchased it and haven't had her torn down yet.
Old Sep 24, 2008 | 01:27 PM
cal2az's Avatar
Az/Texas Rider
cal2az is on a distinguished road
I did the PAIR mod yesterday. Its an easy and straight forward project. I didnt do block off plates, I just flipped the reed stop in both valves.
Old Sep 24, 2008 | 02:01 PM
scarface's Avatar
I flipped the reeds, and I didnt notice any difference in the decel popping? didnt notice any difference in anything personally.
Old Oct 19, 2008 | 04:21 PM
jmarch305's Avatar
jmarch305 is on a distinguished road
Help
Good question. does anyone have any answers.
Old Mar 29, 2009 | 11:16 PM
firehawk's Avatar
firehawk is on a distinguished road
Did mine recently, and yes it revs smoother,response better & less popping; however, now can't ride in the rain much because the engine tends to choke & croak on me due to the water splashing in somewhere!
Never had this with my ole zx6-d & I do enjoy riding in the rain; now with the hawk,can only ride through the drizzle instead somebody help me, please!
Old Mar 30, 2009 | 04:40 PM
Check that the routing of your tank vent tube (the snall one coming out of the bottom, the big ones the overflow drain line) so its not pinched and eliminate the OEM P-trap routing.
Old Mar 30, 2009 | 07:53 PM
Water leak into the sidestand killswitch will do this as well. Member here tuned me in after I was suddenly trapped in a thunderstorm and the bike went nuts - on - off - knock a couple times then off again. It was a very interesting ride back to the shop that night. Thank God it was only 2.5 miles.
Old Mar 30, 2009 | 09:10 PM
I thought it was the SS switch and put a gaiter on it and sealed it tigght. It turned out to be the tank vent line...
Old Mar 31, 2009 | 04:25 PM
tromo01's Avatar
tromo01 is on a distinguished road
i see a lot of peope flit the reeds...i just pulled all the hoses and reeds then caped the intakes on the reed intake..is that ok, or should i put the reeds back in upside down
Old Mar 31, 2009 | 06:17 PM
zmaniv's Avatar
You have to close the port the reason that the bikes pop on decell after upgrading the exhaust is because it flows more and pulls open the reed valve.
Old May 15, 2009 | 12:23 PM
little squirt's Avatar
little squirt is on a distinguished road
just flipped my reed valves and removed all the hoses. made a big difference with my devil exhaust, instead of it popping alot on decel, now it kinda just makes a gurgling sound. much happier!
Old May 15, 2009 | 12:25 PM
nothing's Avatar
ride it out
how do you :flip the reed valves" is it self explanatory once I get down in there?
Old May 15, 2009 | 12:57 PM
Follow the link in Post #7 above, it details it quite well, if you browse down in that thread Greg shows a picture of the reed valve stopper that needs to be flipped.
Old May 15, 2009 | 04:53 PM
yea its very easy, once you take the reed cap off the top of the valve thats held on by two bolts, there is a metal reed with a rubber seal around it, just pop the whole thing out of the valve cover. there is a single phillips screw, just take it out and flip the reed over and reinstall the screw then just put it all back together.
Old May 15, 2009 | 05:05 PM
That phillips head screw might be peened over depending on the year. That will have to be carefully removed without stripping the screw or ground down on the back side.
Wolverine
May 7, 2012 08:56 AM
Barch
Dec 28, 2009 10:22 PM
fundgh
Jul 11, 2007 11:50 AM
F1 Fan in Nascar Land
Nov 30, 2006 01:46 PM
faz
Apr 7, 2005 05:21 PM
