need help with carb hoses :-(
Old Jan 16, 2012 | 11:42 AM
stumplove's Avatar
stumplove is on a distinguished road
Hey all, been rebuilding my hawk with one of my brothers and need some help running the carb vacuum lines and hoses. My brother did the carb removal and I got left with the re-install, ugh. Anyway, I need a bit of help and expertise in dummy terms as to where some of the lines go. First of all, the fittings under the float bowls, where do they get hooked to? Second of all, what gets hooked to the small fittings next to the coolant inlets on the motor? and thirdly, where does the fitting on the rear carb in one of the pictures get plumbed to? Sorry for all the questions but Im still learning the ins and out of this hawk and my poor quality service manual hasnt been much help.
Attached Thumbnails need help with carb hoses :-(-photo-1-.jpg   need help with carb hoses :-(-photo-2-.jpg
Old Jan 16, 2012 | 12:00 PM
That second one is your vacuum line... it runs to the small rear nipple on your petcock assembly that is attached to your gas tank.
The first on is a coolant line. If I'm looking at it right, it's the one that runs to your water pump (the small hose on the side of your right engine case.
Old Jan 16, 2012 | 12:06 PM
Whoops, check that. That coolant line crosses under the carbs and attaches to the thermostat or something...
Old Jan 16, 2012 | 12:09 PM
double post
Old Jan 16, 2012 | 12:10 PM
stumplove's Avatar
ok so in the second one, theres a fitting on both cylinders, both run to a T fitting and that runs to the petcock?
That first one is on the rear cylinder, I was thinking it runs to the valve, not the water pump?
Old Jan 16, 2012 | 12:22 PM
Just cap the front cylinder... it's only there for syncing the carbs. The rear cylinder has the T fitting (and the foot of the T is capped when not syncing the carbs there as well)
Old Jan 16, 2012 | 12:27 PM
Can't remember on the first hose... you're probably right, thermostat doesn't sound correct. There's a pretty intricate diagram of the coolant flow in the manual though. I managed to hook it all up with that:
http://www.superhawk996.net/Honda_VT...ice_Manual.pdf
Old Jan 16, 2012 | 01:02 PM
stumplove's Avatar
now what about the hose fittings on the bottom of the floats?
Old Jan 16, 2012 | 01:21 PM
Those are the float bowl drains and have nothing attached to them....
Old Jan 16, 2012 | 01:23 PM
There should be 2 coolant lines to the carbs one to the front and one to the rear. If you need to know where they are coming from just pull out the service manual and look at the cooling system, though it should be obvious where they go due to the length of the hoses.
Old Jan 16, 2012 | 01:54 PM
stumplove's Avatar
not even a drain hose running down off the bike?
jon1475
Apr 27, 2013 06:57 PM
Torque Junkie
Jun 16, 2009 08:17 PM
3D02
Oct 4, 2006 08:53 AM
superbling
Aug 27, 2006 02:56 PM
sprhawk neil
Mar 1, 2006 04:01 PM
