Header pipe dent removal
Old Feb 24, 2009 | 03:08 PM
I thought I'd throw this out into the KB since I recently PM'd another member on this.
Re: Dent removal
Heres a little trick for that dent in the pipe. Fill that area with water. Wrap a towel around the dented area only and sit the whole thing outside in freezing weather, or in the freezer if you have one big enough. Ensure the dent is right in the middle of the water slug. In the morning the dent will be gone. I did this on a relatively thick steel Jardine header for my '79 Yamaha and it worked like a charm!
Thanks for the tip, but I don't fully understand the process you described. When water freezes it expands about 10%. Don't i need to seal the ends of the pipe? When the water freezes on the ends it will plug them enough to hold hundreds or even thousands of pounds of pressure. What does wrapping the towel do? The ends should freeze first but the towel is wrapped around the dented area first to insulate it and ensure that part freezes last. Once the ends freeze the water in the middle will be compressed and pressure will rise enough to push the dent out. If the dent is small enough it should push out all the way on the first try. How much water do I fill the pipes? You have to fill the pipe so there is enough water to build pressure - I'd say at least a foot on each side of the dent. Too much and you *could* possibly split the pipe, so don't go all out the first try. Guys do this on 2 stroke expansion chambers all the time.
Old Feb 24, 2009 | 03:24 PM
HondaJim's Avatar
Will drum for BBQ
HondaJim is on a distinguished road
I've seen this work on two stroke pipes, especially the expansion chambers, but thicker wall four stroke pipes seem to be a little tougher to do.
I had a set of pipes with a dent in one of the downtubes and I tried this method. Didn't work. What I ended up doing is putting rubber stoppers in the ends of the pipes with a bracket to retain them. 5 lbs. nitrogen pressure and then got the dent area cherry red with an oxy/act torch. Dent pushed right out. Try at your own risk. These were black pipes so I just repainted after the repair. It would probably leave a nasty looking burnt spot on unpainted pipes, although you might be able to sand/polish it out.
Old Feb 24, 2009 | 03:39 PM
FWIW, the Jardine pipes on my Yamaha are probably 1/16" thick carbon steel and are HEFTY! I couldn't believe it worked as well as it did. You have to use enough water and it's absolutely imperative that the dented area freeze last. I cannot stress this part enough.
The other thing is that almost everyone has access to water and a freezer. Not everyone has access to plugs, pressurized gas, and an oxyacetylene torch.
Old Feb 24, 2009 | 03:43 PM
mboe794's Avatar
I've tried the freezing water trick more than once on 2 stroke pipes. Usually have pretty good luck. On large dents doing it twice or more produces good results.
Old Feb 24, 2009 | 03:46 PM
Kendrick's Avatar
The Hypno-Toad
I've heard about the same routine but with dry ice. That's how those paintless dent repair services do it from what I understand.
Old Feb 24, 2009 | 04:04 PM
Byrdman's Avatar
Super Byrd
thats pretty smart.
Old Sep 3, 2009 | 06:06 PM
gravelrash's Avatar
gravelrash is on a distinguished road
header pipe dent fix by freezing of water
This worked brilliantly for me.
here is a link to a web album i shared with some of the boys i ride with. unfortunately in my haste to get it in the freezer, i forgot to take "before" photos.
note the freeezer temp is about -8 degrees Canadian, ie about 18 degrees F. not sure how that compares to your average modern home deep freeze. mine is about as old as I am ..and probably about as energy efficient...
http://picasaweb.google.ca/mbaxter99...at=directlink#
Old Feb 15, 2016 | 04:59 PM
Dantheman's Avatar
Dantheman is on a distinguished road
Now You See it Now You Don't
Header pipe dent removal-image.jpegThis forum is one of the coolest thing to ever hit the world. Did the throw it in the freezer trick.
Old Feb 15, 2016 | 05:10 PM
Dantheman's Avatar
Dented header front cylinder
This is the before pic
Old Feb 15, 2016 | 07:10 PM
Cadbury64's Avatar
VTR virgin
Well I'll be darned! What a great idea. I've got a very similar dent to yours Dan. May be one day I'll give this a try.
Old Feb 15, 2016 | 07:25 PM
finepooch's Avatar
wow! when i started reading my skeptical mind immediately judged this as hocus pocus. then all the reports of successful repairs and i am transferring this file into the "strange but true" folder. nice tip.
Old Feb 15, 2016 | 10:00 PM
It is amazing, and to think water is also one of the only substances that is lighter as a solid than a liquid. God's own design.
Old Feb 16, 2016 | 04:41 AM
finepooch's Avatar
God's own design.
LOL!
Old Feb 17, 2016 | 04:45 PM
Fastguy59's Avatar
I giving this a try tomorrow night when the overnight temps come back down into the freeze zone! Thnx for posting this!
Old Mar 9, 2016 | 12:31 PM
Fastguy59's Avatar
I did give it a try but even with temps in the 18 degree range (digital thermometer measured) the water in the pipe would not completely freeze. I'm thinking the carbon coating inside the pipe may have some influence. I'm on the hunt for a friend with an empty chest freezer @ 0 degrees... More later..
Old Mar 9, 2016 | 05:24 PM
Chest deep freezer is what i have always used. I have three for beer making so just plan use in between fermentation periods
Old Mar 11, 2016 | 01:04 AM
NZSpokes's Avatar
Yerp done this on my 2 smoke pipe.
Make sure the wife is not home though.
Old Mar 11, 2016 | 10:24 AM
waltr's Avatar
Not Realy A Squid
waltr is on a distinguished road
Here in the pacific northwest we don't need to ferment in a freezer. There are only about 2 months that I even have to give any thought to temperature.
I do have 4 refrigerators though, and one of them actually has food in it!
Old Mar 11, 2016 | 11:22 AM
Ahh, the Oil thread of beer making... Fermentation process and Temps
I'll leave that for another forum and just say.. I control fermentation temps when i brew..and I think it matters ,,It made a difference in quality and consistency when I brewed in Corvallis Or, Fairbanks AK, South Carolina, California, and now Texas...but to each his own, do what makes beer for you.
Old Mar 11, 2016 | 06:16 PM
Probably has nothing to do with our bikes, but interesting nonetheless.
Dented pipes can make power? What the...
Old Mar 11, 2016 | 11:23 PM
NZSpokes's Avatar
Dented pipes can make power? What the... Exhaust Header Bash! Testing Power Loss From Dents - Engine Masters Ep. 4 - YouTube
Thanks, that was a great watch.
Old Mar 12, 2016 | 08:32 PM
Cadbury64's Avatar
VTR virgin
After watching that, I feel a lot better about my dented header!
Old Mar 13, 2016 | 11:33 AM
finepooch's Avatar
all the sleep i lost because of the dented header on my aprilia mxv450 was for nothing. lol
Old Mar 17, 2016 | 11:50 AM
NZSpokes's Avatar
Does make on wonder if plugging it and heating water would work as well?
Old Mar 17, 2016 | 12:19 PM
I'm not really wondering, but I think you should video your attempt and have someone standing by (at a distance) to post the video here on the forum postmortem.
Old Mar 17, 2016 | 01:14 PM
Cadbury64's Avatar
VTR virgin
Well said! Look up "boiler explosions" on youtube to see the result.
Heating water to create pressure potentially results in catastrophic explosions, because if the pressure is released the water turns to steam and expands to many, many times its liquid volume.
It would be much safer to simply use hydraulic pressure with cold water, and a grease gun or similar to generate the pressure.
The nice thing about the ice method is that the ice forms the necessary perfect seal either side of the dent, before the liquid by the dent freezes and expands.
Funnily enough Spokes, I was also bidding on the pipe that you bought, with the intention of using the headers to replace my dented system. You got it for a good price while my back was turned...
Old Mar 17, 2016 | 04:33 PM
NZSpokes's Avatar
You just know that makes me want to try it more......
Old Mar 17, 2016 | 05:10 PM
My work here is done.
Don't forget the video.
Old Mar 17, 2016 | 05:17 PM
NZSpokes's Avatar
So it was you that knocked it up so high!
Old Mar 17, 2016 | 07:12 PM
Cadbury64's Avatar
VTR virgin
Sorry about that, mate. Not sure I'd consider $25 high though.
