Fork Oil Level
Old Oct 14, 2008 | 09:02 PM
MACdADDYBD1's Avatar
REDUNDANCY DEPT. HEAD
MACdADDYBD1 is on a distinguished road
Fork Oil Level
On all of my current dirt bikes, the fork oil level can be measured and altered to change performance. I even have the device that is used to measure and adjust these levels. The fork cap is removed along with the fork spring. I think the fork is collapsed or compressed to bottoming. Then held straight up vertical and the fluid level measured through the top of the tube and either added to or sucked out. Does anything anywhere tell what the level should be for fork fluid on the Hawk forks? All I found in the manual whas the amount to add after draining. I just want to check and adjust as needed.
Thanks in advance for your help.
Old Oct 18, 2008 | 03:31 PM
BeerHunter's Avatar
Slacker
You need the "air gap" for the forks. A quick search turned up This Thread
AngryOlaf
May 25, 2010 09:39 AM
5150
Jun 8, 2009 06:01 PM
mcadena89
Jun 3, 2009 12:04 AM
getagripgreg
Mar 5, 2007 11:56 PM
superbling
Jan 16, 2005 02:43 PM
