[ KB ] VTR Clunk Die Fix
Old Jul 15, 2004 | 08:43 AM
mamisano's Avatar
Super Moderator
mamisano is an unknown quantity at this point
Category: Common Problems
Type: How-To
Article Name: VTR Clunk Die Fix
Author: mamisano
Description: A common problem with the Honda VTR-1000 is a "clunk-die" sequence that happens at idle.
>>Read Full Article
Old Jan 25, 2006 | 07:39 AM
superbling's Avatar
This guy recommends using dia-electric grease on the slides for this proceedure.
While doing the shim-the-stock-needles mod for better 3-4krpm performance, I followed this advice and lubricated the slides with this grease. I was rewarded with a very stuck slide within a couple of days. I had to limp home on basically one cylinder for about 15 miles!
I related my troubles to a very knowledgeable local rider who said to never use a petroleum based lubricant in a gasoline environment. DOH! That makes perfect sense. After cleaning, I used Honda silicone spray on the slides. That was about 14 months ago with no issues.
Anyone with a better recommendation? I don't recall what or if the factory service manual says anything about this.
Old Jan 25, 2006 | 07:53 AM
CNI Dawg's Avatar
Re: [ KB ] VTR Clunk Die Fix
Ya I was wondering about why he did that.
Thought he might have problems after a time.
I used a very small amount of silicon/teflon spray with NO oil in it.
I wiped off any excess so there was only a little on the friction spots (both inside the slide and outside of the slide)
Old Jan 25, 2006 | 09:21 AM
jschmidt's Avatar
jschmidt
I don't realy see why the slides would need lubrication. At least this fix seems to be generally related to the problem, but I don't think it offers a solution.
Circuit_Burner
Oct 14, 2013 06:44 PM
maniac2313
Nov 13, 2010 10:40 PM
Crashrat
Sep 28, 2010 06:24 AM
nova_scotian_996
Jan 1, 2007 03:37 PM
Rufion
Jan 13, 2006 07:15 AM
