Coolant leak at the front carb.
I have a coolant leak on my front carb at the fitting that the coolant comes into and then back out to the rear carb. Is there a seal or anything that can be replaced?
Already did that. Hoses and clamps all in good shape. On the carb component diagram, there are two small O rings on that fitting that goes into the carb. Can they go bad? It looks like I can order those. If I decide to try that, it looks like the hose fitting is held in place by the side bracket that holds the carbs together. Is that correct?
Reading some other threads about leaking issues, it seems common for older bikes to get crusted up inside requiring extensive soaking to try to clean up internal passage ways. At that point, some opt to get rid of the coolant lines altogether. I really don’t want to go to the extreme of taking the carbs all apart .
Thank you for your response. I am leaning on doing what you suggest. I’ve looked for a “ how to”, for bypassing the carbs coolant connections. Since you have already removed them from your bike, would you please let me know that needs to be disconnected, capped or clamped off or re-routed if necessary. Thanks again for your help.
On the subject......would removing the carb heating/coolant line altogether and capping the 2 barbs lead to any issues?
It would leave the coolant bypass line as the lone circulation with a closed thermostat..................
No issues removing the flow of coolant to the carbs.
I found over the years that even with timely draining flushing and replacement of the coolant the carb fittings, which are there to heat the carburetors in cold weather as stated, become clogged up anyway...
I have 5 sets of carbs and every 12000 miles or so I swap them out with rebuilt units. Also shares wear on the slides, which have a friction reducing coating.
Years ago I bought a few spare replacement fittings and O-rings because even hot ultrasonic cleaning will not open clogged fittings.
Being I live where it snows, those bigs carbs, the biggest Honda put on anything, need all the help they can get to atomize distilled dyno juice.
