WTB Valve cover gaskets
Old Mar 17, 2010 | 04:25 PM
Sprayall's Avatar
Sprayall is on a distinguished road
Okay, I've tried so many websites (I think every site listed on here) looking for the valve cover gaskets. Gary at overstockpartsgalore.com says they don't have any in stock and no date for receiving any either. Am I stuck with going to the dealer on this one if I don't want to wait for Gary (it sounds like the cam chain is slapping around and the CCTs are on their way-scared to ride it)? Anyone know of someone else that normally carries them?
TIA
Old Mar 17, 2010 | 04:43 PM
TIA
Is there a reason you need to replace them? I've had my valve covers off at least 5-6 times and I am still using the original gaskets. They are glued to the valve cover and can be reused a number of times.
Old Mar 17, 2010 | 04:56 PM
Sprayall's Avatar
Yeah, I've wondered about that. Wanted to be safe-I'll be doing this at a friends house a ways from town, and it's my only transpo. I just didn't want to have the bike apart for several days because of a shady gasket. Bring a tube of RTV right?
Old Mar 17, 2010 | 05:01 PM
No need at all. I can post some pics if you like as mine are sitting on the bench right now. Just pull the covers and the gaskets will come with them.
Make sure they are clean and reinstall them dry. No muss no fuss and you are good to go.
Just make sure you don't over tighten the valve cover bolts or you will end up like me with the heads pulled to fix the threads......
Old Mar 17, 2010 | 05:43 PM
residentg's Avatar
servicehonda.com
Part Number 12391-MBB-000 "GASKET, HEAD COVER" $25.17
front and rear gaskets are the same so you will need to order two. Usually a good cleaning in soap and water, not solvents, will do the trick.
JB
Old Mar 17, 2010 | 06:44 PM
Sprayall's Avatar
Right on. I did see the "GASKET, HEAD COVER" at several sites. Thanks guys. Hey 8541Hawk, are you using helicoils to fix the threads, or plug welding? Just curious. Hopefully never in that position myself.
Old Mar 17, 2010 | 06:58 PM
I put a helicoil in for now. I plan on doing my motor work next year but, as the heads were off, I had to do a little porting....
syf
Mar 31, 2009 04:13 PM
flyingeyepro
Feb 3, 2009 01:47 PM
Reba
Jan 29, 2008 06:48 AM
mikenap
Jun 14, 2006 04:46 AM
EngineNoO9
May 23, 2006 09:27 PM
