Went to the drag strip..........
Old Jun 17, 2005 | 11:09 PM
RymerC's Avatar
RymerC
Man, that thing is just getting broken in!
Seems the straps that tie-down the front end really help. The clutch gets funny at the strip, but nobody seems to know why. You also might want to try raising the rear a little by adding a shim under the top shock-mount. about a 5 or 6 mm shim is good. Mine doesn't pick the front up nearly as easily with the rear raised.
Old Jun 18, 2005 | 10:12 PM
BooYeah's Avatar
BooYeah
Re: Went to the drag strip..........
Its the opposite of that, if you drop the rear all the way down it makes the bikes pivoting point much harder to raise and thus makes it much harder to wheelie. Look at the fastest bikes in the world they are all slammed to the ground. the only reason cars raise it is to fit big tires.
Old Jun 22, 2005 | 01:00 AM
mikecronis's Avatar
mikecronis
Yep. 'Busas with tiny clearance drag well. Lower is better.
YellowHawk
Jul 12, 2007 09:44 AM
jtgraha2
Mar 26, 2007 06:12 PM
Speed_Demon
May 16, 2006 12:11 PM
denmah
May 4, 2006 01:38 PM
Philipian Ricer
Apr 11, 2005 10:33 PM
