Top Speed ???
Old May 30, 2010 | 10:47 PM
dcohawk01's Avatar
dcohawk01 is on a distinguished road
Top Speed ???
New guy here. New to the SH as well.
I had a chance / reason / excuse today to open the hawk up on a long straight road with little trafic. My understanding is these things do about 150 mph tops. I didn't quite top it out, but it indicated 170 mph. Held that speed for about 5 miles.
I bought the bike, a 2001, with D&D slipons and dont know what else. I took the rear sprocket up two teeth. It only had 4000 mile on it so I assumed it was basically stock.
What else could the previouse owner have done to make this thing run that fast?
Old May 30, 2010 | 10:55 PM
autoteach's Avatar
If you have a gps unit, use it. I think that you will be surprised by how "slow" your bike is.
Old May 30, 2010 | 11:03 PM
It's just the speedo being a bit optimistic....... I've had mine to the rev limiter in 6th (10.3k rpm) and calculated a true top speed (gearing, tire diameter & RPM) of 157 and the dyno says a top speed of 159 and the needle was buried past 180mph both times..... So an indicated 170 is around 135-140mph.
Old May 31, 2010 | 06:00 AM
Just_Nick's Avatar
Who are you?
I had 142 with 160 indicated
Old May 31, 2010 | 06:45 AM
Two teeth up on the rear sprocket is a 4.7% change rounded off to 5%... And then considering the speedo is usually about 10% optimistic to begin with, that's a 15% error give or take... Say 13% at best, 17% at worst (8-12% speedo error)... So you where actually travelling at a speed somewhere in between 140-148 when your speedo said 170... That's a fairly typical for a VTR...
Old May 31, 2010 | 09:03 AM
Tire slip at that speed is between 5 and 10% as well.
Old May 31, 2010 | 09:16 AM
Ah, I knew I had forgotten something...
That makes 125-140 mph then...
But actually 5-10% seems a bit high... From what I have read, a bit less is usually the case... But it's still a far cry of the 170 that the speedo reads...
Also at that speed you should probably take into account that the tire will grow enough to actually impact the roadspeed
Old May 31, 2010 | 09:23 AM
jay956's Avatar
mine was 18% off with -1 +2
seroj
Aug 29, 2022 07:18 PM
lukenukem47
Apr 28, 2011 06:52 PM
uchi
Oct 4, 2009 05:28 PM
renaisstar
Jan 24, 2008 07:05 PM
Randman
May 30, 2007 06:59 PM
