Steering Stem OD
Old Sep 28, 2014 | 08:49 PM
UCF Eric's Avatar
Steering Stem OD
Long shot, but does anyone know the OD of the Superhawk steering stem where it presses into the bottom triple tree? I'd rather not take mine apart to find out. Thanks in advance.
Old Sep 29, 2014 | 06:53 AM
Jack Flash's Avatar
Well take off, eh.
Do you want with or without bearing race in ?
Old Sep 29, 2014 | 03:54 PM
UCF Eric's Avatar
I'll take both if you have it.
Old Sep 29, 2014 | 06:26 PM
Jack Flash's Avatar
Well take off, eh.
55mm straight to the frame. Bearing race is too far into the frame, I can get caliper in there. Also, from cylindrical to roller type bearings, the race is different. So, measurement becomes useless.
Old Sep 29, 2014 | 08:17 PM
UCF Eric's Avatar
That's seems awfully large for a steering stem diameter. I thought it would be closer to 28mm or so.
Old Sep 29, 2014 | 09:21 PM
OEM Steering stem OD
Top 26mm
Bottom 30mm
OEM bearing race OD
Top 47mm
Bottom 55mm
Old Sep 30, 2014 | 08:50 AM
Jack Flash's Avatar
Well take off, eh.
Thanks Erik for clearing that up. I really misread his post.
I will now curl up in a corner, and kick myself...;O)
Old Sep 30, 2014 | 05:51 PM
insulinboy's Avatar
I was about to say the ST is torn apart getting new stem bearings (and now a new stem since the old stems threads tore off when removing the stearing head nut.. damn 25 year old bikes that have never had any maintenence done) and uses the same bearings as the VTR so I'd get a measurement for you, but looks like I was beat to the punch
comedo
Mar 25, 2010 08:24 AM
Erik S.
Dec 5, 2009 11:39 PM
inderocker
Aug 13, 2009 09:09 AM
Dan Cronin
Apr 17, 2009 05:22 AM
FL02SupaHawk996
Apr 28, 2008 04:23 PM
