spark plug removal
Old Feb 5, 2009 | 08:18 AM
Denverhawk's Avatar
Street Fighter
Denverhawk is on a distinguished road
spark plug removal
Hey All,
A quick question, I did some work on the bike (removed pair system, installed K&N air filter, and installed de-baffled pipes) and yesterday re-installed the tank but the bike had trouble starting/running. Twice it actually ran for 4-8 seconds before dying and then, with continued cranking it wouldn't start. I realize there are several possible factors and tomorrow off comes the tank again so I can double check my work but because it ran (albeit briefly) I believe it's getting gas and spark. But I still want to confirm spark, and remove and replace the spark plugs while I'm at it which leads me to my question. I have a Haynes manual and feel confident in my ability to do this, however I don't have the OEM tool kit, does any one know a suitable replacement socket/tool or do I have to buy a OEM tool or kit to remove the spark plugs?
I'm working under the assumption that the air/fuel mixture is off and am hoping that a look at the plugs can confirm this and maybe even tell me if it is too rich or lean but of course I'd welcome any suggestions from the forum. I have K&N Stage One Jet kit that, if my diagnosis is right, I hope will solve this but I'm nervous that the bike won't run at all. I was ready for the possibility of the motor running rougher but was surprised that it wouldn't run at all. I'd also considered the lack of back-pressure from the de-baffled pipes but while the motor needs back-pressure to run optimally it's shouldn't need it to run at all... right? Anyways, any thoughts on the whole dilemma and suggestions on the correct tool to pull the plugs would be greatly appreciated. I'm posting this, then going to work for the day but will be back online tonight. Thanks in advance!
Old Feb 5, 2009 | 08:47 AM
FL02SupaHawk996's Avatar
Fastest Color
Originally Posted by Denverhawk
Hey All,
Sounds like you got the vac hose on the wrong nipple on the fuel petcock when you put the tank back on...where do you have the tubes connected to the petcock under the tank?
RC
Old Feb 5, 2009 | 09:35 AM
j shizzy wizzy's Avatar
mildly retarded
Denverhawk, are you the guy with the burnt orange hawk?
Old Feb 5, 2009 | 01:14 PM
RK1's Avatar
RK1
A deep 18mm socket will work on the plugs.
Old Feb 5, 2009 | 01:19 PM
Fastest Color
+1, just put a piece of rubber in the socket to grip the plug and pull it right out
RC
Old Feb 5, 2009 | 01:30 PM
RK1's Avatar
RK1
RC
That's a great idea. I've been lifting them out with a pen magnet which works also.
Old Feb 5, 2009 | 01:31 PM
Little_Horse's Avatar
2nd mouse gets the cheese
be aware though some 18 mm deep sockets have too big of an outside diameter and will jam in the valve cover, and then take you half an hour to pry loose... at least mine was so either find a thin walled socket or you might have to sand it down. Or maybe I am the only one with this issue in which case just ignore...also I agree it sounds like the air line to the petcock is wrong.
Old Feb 5, 2009 | 01:43 PM
trinc's Avatar
a quality 18mm socket will be too large. a cheap socket set will be thinner and may work. i opted to just buy the OEM ( i think it was $10 ). i imagine you could run one on the grinder but i'm not that poor.
tim
Old Feb 5, 2009 | 01:53 PM
Snap-on, Matco, Mac all make 18mm Spark Plug sockets. A cheaper socket will actually have a larger outside diameter, since they use cheaper steel with less hardness they make the walls thicker.
I changed my plugs this morning and made the same mistake, but found it quickly. The small vacuum hose goes on the SIDE port of the fuel valve under left rear of tank.
Old Feb 5, 2009 | 02:15 PM
yamahadm250's Avatar
yamahadm250 is on a distinguished road
double check the vacuum lines.make sure they are connected to the right places.sounds like you have the petcock vacuum crossed with another hose.
Old Feb 5, 2009 | 03:25 PM
and when you remove the PAIR sys there is a vacuum hose or nipple I think you have to cap/plug, and seal the hole in the bottom of the airbox from the PAIR hose,plus flip the check valves in each valve cover and plug thehose nipples. Go to greg's new site for instruction...
Old Feb 5, 2009 | 04:09 PM
motojoe's Avatar
Sexual Daredevil
I just use some old cheap Honda tool kit sparkplug wrench that is deep and thin. I forget which bike it came from, but I been using it for years.
Old Feb 5, 2009 | 04:52 PM
Denverhawk's Avatar
Street Fighter
Wow, Thanks for all the help! I'm heading out to the garage later this eavening to double check the placement of the vacume hose. it would be great if it was that simple. The plugs need to be changed either way and I need to do it myself so thanks to all for the suggestions I'll try my cheap socket set and go from there. I'm impressed with and gratefull to all the forum members, I've never participated in a forum before and now wished I had years ago! You guys rule.
Old Feb 5, 2009 | 04:57 PM
drew_c14's Avatar
I can say 99% for sure that you hooked the hoses up wrong. I had the EXACT same thing happen first time I took off my tank.
Old Feb 5, 2009 | 04:58 PM
Denverhawk's Avatar
Street Fighter
Only one way to find out...
Old Feb 5, 2009 | 05:00 PM
drew_c14's Avatar
this is what it should look like
front looking back
from the back
Old Feb 5, 2009 | 05:03 PM
mildly retarded
If you don't have a manual, there's one in the knowledge base section of the forum.
Old Feb 6, 2009 | 08:11 AM
Denverhawk's Avatar
Street Fighter
... Success! It was a vacum line misplacement issue! Thanks to all!
Old Feb 6, 2009 | 08:14 AM
Fastest Color
U are welcome
Old Feb 6, 2009 | 08:24 AM
RK1's Avatar
RK1
Ha! Congrats, Denver. That's almost always what it is! (been there done that)
Hawke
Sep 24, 2014 10:47 AM
WhOrD
Mar 12, 2013 07:27 PM
seattlesucks
Jul 26, 2007 06:48 PM
ATLSHawk98
Dec 21, 2006 09:32 AM
motojoe
Oct 3, 2005 04:19 PM
