Second track day - Got to test my leathers
Haha, so my first track day was last friday at Summit main. Then Wed this week I went up to Thunderbolt raceway in NJ...First two sessions of the day were great, that track is awesome! The third session I asked a control rider to show me the lines a few laps, so he took me out with two people following me. The second lap I was coming out of a slow tight left, turn 5 I think, and I THINK that I came in hot and I was off the throttle through the begining of the turn then when transitioning into the throttle I may have grabbed a little too much too early while fully leaned over hanging off....rear tire spun and I was on my *** before I knew it...slid off the track over some gravel and into the grass...picked my bike up, it started fine, tires looked good, and rode back to the pits....The leathers did their job, I didn't have a scratch or bruise.
Luckily I was able to keep riding! My clutch lever was curled up and my shifter bent and half of the toe section broke off...I straightened them out and went through tech again, kept riding! yea!
So what it comes down to is I went there with a street bike I was taking to the track, and I came home with a track bike I can ride on the street hahaha.
if anyone has a shifter let me know! I'm trying to go to Nelson ledges next weekend.
I'm on pretty fresh Power Pures, maybe 1000 miles on them. It was only the second lap when I went down, so they may not have been up to temp.
How would a braced swingarm have helped? The problem was rider error on my part, I don't think any parts would've kept me from going down.
Well once you have ridden a SH with one installed you will have a better idea of what I'm talking about.
The stock swingarm is about as stiff as some cooked pasta.... So when you are in a corner and spin up the rear, it tends to snap back straight and cause a lurch in the chassis which is what, more than likely, caused you to lowside.
With the brace installed, that flex is now gone. At that point spinning up the rear is pretty much a non-issue. You hear the motor rev and also the tire spinning but the chassis is completely stable. So the bike goes from being a handful when you break the rear loose to how big of a darkie do you want to leave exiting the corner.
Yea I was thinking about how it would help and thats exactly what I figured it would do...the swingarm flexed while the tire had grip, then when it lost grip the swingarm straightened out and the tire had no chance to get grip again...now I'm wondering if I should wait to get some more work done before going back
There are times though when you just snap the throttle too much, and then no parts in the world can save you from your own stupidity... Ask me how I know...
If I where you, I'd invest in a pair of T-rex framesliders, and a set of rearsets first... That keeps you from breaking important and expensive stuff when having fun... Then hit the track and practice...
And since it seems the one wrenching on that bike has mostly concentrated on the engine... Which is ***-backwards if you ask me, I'd consider a bit of upgrades to the chassi as a future investment... But that comes well into learning to ride that bike...
Either new springs/valves up front and an F4i or Öhlins shock in the back... Or go whole hog and swap the fork and swingarm... But start with the suspension...
Yea frame sliders are the first thing on my list. Hopefully I don't go down again before I get them lol. Over the winter I plan on doing a CBR1000 front end conversion, and now planning to brace the swingarm...Is there a better swingarm that can swap in easily? I'm remembering reading you can swap the RC-51 swingarm in?
Well... I'd say one more part is actually involved in that... The stock rear shock is abysmalic... With a more rigid swingarm it's even worse... But get the shock replaced and tuned in (F4i/Öhlins) and together with a rigid swingarm, and laying darkies is quite fun... It becomes a much more easily controlled bike when only things that should flex does, and more importantly only in the directions it should...
medium fast guy
I see 2 choices for you, one, crash and get it over with, two, slow down to a comfortable pace and work your comfort level and speed up. Take time to learn the track, ride smooth, and find places where you can pick up the pace.
well my track day went good. i was bumped to intermediate by mid day, not too bad for my second track day as i was passing in novice like crazy and chasing guys through corners pretty hard. i worked on my posture, i was "kissing the mirror" and the bike felt fantastic. the rear set spacers worked great but i didnt get a knee down at all today. likely from the raised seat position and the raised rear sets. but i was much faster and much smoother than i was at my last track day. i did go off the track once. on the back straight im probably hitting 4th gear for a few seconds and then this corner is a high rpm second gear corner and i came in too hot, it was cold out, second lap, tires werent up to heat and the bike drifted wide and i stood it up and rode it off the track into the grass. managed to keep her up though. but i pushed a good pace so i was happy with myself. my slipping clutch gave me problems and let guys get past me on the main straight but other than that the bike worked great and i had a great time
also after doing some thinking i didnt push as hard as i could have. the cold air and overcast for most of the day didnt warm the track and im running on tires that are pretty crappy up the middle but have lots of side life so i think i kept thinking id have grip issues and didnt push nearly as hard as i could have. but ive got slicks now and tire warmers coming my way in the winter so ill be sure to get out on those and really push the pace
oh and i got some good vids of the day ill edit and get up in the next few days
