running rough
running rough
Ok so i got the bike out last night after some cosmetic modifications! It is running a little rough! Thinking it's from the gas that has been in it all winter. There isn't much in it do you have any suggestions on what to do to get it to spark back to life?
I did put new plugs in her and cleaned the air filter. Other than that i didn't do anything else.
Any tips would be greatly appreciated!!!!!
i started it regularly through the winter to prevent the same gas from sitting in the carbs to long!
I will ride it over and get a full tank of gas tonight and see if that helps!
If you took the tank off check that 1st. I learned the hard way, but these guys fixed me up..
If not sure what that is, I have a pic on a post that E.Marquez put up. note the small grey hose
https://www.superhawkforum.com/forum...ference-30025/
