running rough
Old Mar 29, 2013 | 07:00 AM
pchrist's Avatar
pchrist is on a distinguished road
running rough
Ok so i got the bike out last night after some cosmetic modifications! It is running a little rough! Thinking it's from the gas that has been in it all winter. There isn't much in it do you have any suggestions on what to do to get it to spark back to life?
I did put new plugs in her and cleaned the air filter. Other than that i didn't do anything else.
Any tips would be greatly appreciated!!!!!
Old Mar 29, 2013 | 07:17 AM
Fresh gas first..
But cleaning the carbs may be in order...... Most times untreated gas left for that long will form sludge and deposits in the carb.
Old Mar 29, 2013 | 07:20 AM
pchrist's Avatar
i started it regularly through the winter to prevent the same gas from sitting in the carbs to long!
I will ride it over and get a full tank of gas tonight and see if that helps!
Old Mar 29, 2013 | 06:48 PM
yamahadm250's Avatar
yamahadm250 is on a distinguished road
you probably already know this, but check that the fuel petcock vacuum is on the correct port.
Old Mar 29, 2013 | 08:57 PM
whatthefnck's Avatar
THE LANE CARVER
ya I agree with yamahadm250
If you took the tank off check that 1st. I learned the hard way, but these guys fixed me up..
If not sure what that is, I have a pic on a post that E.Marquez put up. note the small grey hose
https://www.superhawkforum.com/forum...ference-30025/
Old Mar 29, 2013 | 08:59 PM
THE LANE CARVER
let us know what it was when you figure it out...
Old Mar 30, 2013 | 12:28 PM
pchrist's Avatar
thinking it's that port! Dam it!!! Going to check it later tonight
Denverhawk
Feb 20, 2009 07:24 AM
Motohead
Feb 23, 2008 09:42 AM
Herbert
Jun 10, 2007 01:09 AM
Babelfish
Jun 8, 2007 03:50 PM
spdrcr
May 18, 2007 05:43 AM
