Rider Weight
Old 03-16-2008, 06:17 PM
steener's Avatar
steener is on a distinguished road
Talking Rider Weight
Read many forums regarding fork/shock/suspension upgrades. Are these mostly needed due to elevated rider weight? I weigh 160 and find the stock settings just fine.
steener is offline
Old 03-16-2008, 06:28 PM
I think the quoted "out of the factory" settings are for a 180 pound rider.
nuhawk is offline
Old 03-16-2008, 06:29 PM
drew_c14's Avatar
If the stock settings are good for you then I wouldn't even worry about it. But yes, rider weight plays a role in upgrades.
drew_c14 is offline
Old 03-16-2008, 06:36 PM
No, most of the mods are done because the front suspension does not balance well with the rear in the stock form. The front is too soft and the rear too stiff.
nuhawk is offline
Old 03-16-2008, 07:05 PM
RK1
RK1's Avatar
I weigh about 146 lbs. soaking wet and find the front suspension inadaquate.
RaceTech claims it is set up for someone who weighs about 115 lbs. Do you know anybody over the age of 11 or 12 who weighs 115 lbs.? In my opinion, the biggest F*ck up Honda made with the VTR is the front suspension.
RK1 is offline
Old 03-16-2008, 08:38 PM
sassage's Avatar
yes...bigger guys like me need a little work for the suspension
sassage is offline
Old 03-17-2008, 03:43 AM
The front matches 130 pounds, the rear 300... hence the need for work...
Tweety is offline
Old 03-18-2008, 05:33 PM
JamieDaugherty's Avatar
I've found the rear to be soft too. It's exaggerated by the soft damping of the stock shock as well. I've found the front to be pretty solid, even over the bumps in turn 1 at Mid-Ohio.
JamieDaugherty is offline
Old 03-18-2008, 06:15 PM
superhawk22's Avatar
Lack of adjustability and when pushed to limits it pushes back!
superhawk22 is offline
tremaineiz
04-29-2007 10:15 AM
captainchaos
01-23-2007 03:51 AM
Radiaoktiv
10-24-2006 08:11 PM
Scooberhawk
08-01-2006 02:36 PM
ta2av
01-30-2006 02:03 PM
Quick Reply: Rider Weight
