Restoring satin finish on Leo Vince slip-ons
Old Jun 19, 2008 | 06:12 PM
comedo's Avatar
I used some fine steel wool and a Scotchguard pad to remove some filth from my 01 VTR's alloy Leo Vince slip-ons. The filth is gone but so is the nice satin finish in the area I cleaned. It is is now polished to almost a mirror finish. Any suggestions about abrasives or techniques that I can use to get the finish back to the way it was?
Thanks in advance for your help.
Old Jun 19, 2008 | 07:13 PM
It may not perfectly match the finish they came with but if you want a satin finish experiment with a few different grades of sandpaper. If you wet sand aluminum up to say 400 or 600 grit and leave them like that they'll have more of a satin (smooth titanium like) finish. Without going into a polishing step by step you're basically doing like you were going to polish for a mirror finish without the final steps. Whatever you do you'll most likely have to do the whole thing though for it to match. If you want the rougher finish I think they come with (I have carbon leos but have seen the aluminum ones) you may try an even rougher grit.
Old Jun 19, 2008 | 07:18 PM
From what I remember about the way they're finished, anything you clean them with that's abrasive-wire brush, steel wool etc is going to change the finish 'cause it's just raw unfinished aluminum. Whenever I try to clean something I always like to start mild and go up from there. Start with mild cleaners and if that doesn't work go a little stronger until something does. Maybe next time try some simple green and an old toothbrush first since that won't mar or change the finish.
Old Jun 19, 2008 | 09:26 PM
comedo's Avatar
Thanks, captain. You're right. I was a bit too aggressive with my cleaning effort. I'll try some of your suggestions.
2whltuner
Aug 8, 2015 02:48 PM
salmanilla2000
Jul 9, 2009 12:39 PM
98vtr1000
Jun 9, 2007 11:03 AM
MessF4
Oct 23, 2006 08:26 AM
GregHimmel
Oct 17, 2006 07:15 PM
