removed sproket cover...no clutch needs bled?
Old Apr 8, 2008 | 05:07 AM
andy9743's Avatar
i did search and i found my answer (i think) but looking for confirmation...took off the front sprocket cover to clean the gunk out of it, put it back on and now i have no clutch. does it need to be bled? that seems to be what i'm finding using the SEARCH
thanks
andy
Old Apr 8, 2008 | 05:26 AM
hawxter996's Avatar
ole dirty bastard
yes it does.
Old Apr 8, 2008 | 06:13 AM
Hotbrakes's Avatar
I've pulled mine off and Reaper's to change sprockets and we bolted them right back on with no problems.
Old Apr 8, 2008 | 06:45 AM
calitoz's Avatar
Escape Reality
same...check alignment..the system is self contained it simply pushes the clutch rod..check if there is binding
Old Apr 8, 2008 | 10:33 AM
pigwings's Avatar
pigwings
Removed mine, and the cover won't go back on. Didn't touch the clutch rod or brake lever.
Drained the fluid - same problem.
Old Apr 8, 2008 | 10:55 AM
RickB's Avatar
Check alignment as other said. I've had mine off and didn't have to bleed it. It seems that the rod will come out slowly on its own if there nothing to stop it. If your fluid level was low you could have sucked in some air when it extended out. You can try holding the clutch in overnight with tape or something to the grip and see if it helps... This trick works well on spongy brakes - I take it that it allows the air bubbles to rise up and self bleed.
Old Apr 10, 2008 | 09:39 PM
Alpar's Avatar
Alpar is on a distinguished road
I'm having the same problem... i think i'm gonna try bleeding it like that. also how do i check the alignment / whats that all about??? i'm looking through old posts, but haven't found it yet.
Old Apr 10, 2008 | 09:44 PM
superhawk22's Avatar
To avoid this problem in the future just pinch the hose with vise grips and something to protect the the hose.
Old Apr 11, 2008 | 03:07 PM
I wouldn't squeeze the hose. The recommended way is to put a tie wrap around the clutch lever and grip. That will keep the slave from working its way out.
Old Apr 11, 2008 | 04:25 PM
+1, should not have to bleed or anything, just bolt it on properly. Besides the zip tie I use a VG Quick-Grip to hold the slave cylinder in. I also use kerosene and a brush over a pan to clean the crud off. Using a chain wax makes a sticky goo, which is another reason I like my Scott Oiler.
Old Apr 14, 2008 | 05:36 PM
As long as you don't mash the thing the only way something would happen is if there was already something wrong with the line in the 1st place. I've done it for years and they even make tools to do it but do as you wish.
Old Apr 14, 2008 | 07:00 PM
LOL!!
Old Apr 14, 2008 | 08:05 PM
And once upon a time an ice pick was the preferred tool for frontal lobotomy, don’t make it the best tool for the job.
You can remove the clutch slave cylinder and replace it without re bleeding as long as you do not touch the lever.
Although it’s never a bad idea to flush fluid and re-bleed the system. All but silicone fluid is hydroscopic so, once the container is open, it’s absorbing water. Change often and your better off.
Old Apr 14, 2008 | 08:07 PM
The point is that once it's flat most newbies are in an uphill fight to get it reinflated. I know I was when I did mine the first time - what a pain in the ***!
A Mighty-Vac or similar contraption available at most parts stores is a valuable tool. Usually about $50 for a decent setup.
There are two players with these hydraulic systems. One is the size of the uptake of the master cylinder and the other is the viscosity of the fluid.
Because the uptake of the master cylinder is microscopic and the fluid doesn't readily run down hill, pumping the lever is like - well, you know.
The fluid is best drawn through the system via a vac that encourages the fluid to move. Under negative pressure the master allows much more fluid to enter the system than under normal lever conditions.
My first attempt was a four hour mess that ended up all over the shop floor due to a bad kit. When TxSuperChicken and I overhauled the MC this winter we had pressure up in ten minutes and had the fluid changed out to dot 5.1 in about another three.
Lesson learned here. He pumped up the system with dot3 because of the viscosity issues with the other fluids. Once it pressurized - we pumped that all out and used the old fluid to draw the new fluid in. Worked great!
Old Apr 14, 2008 | 08:42 PM
thetophatflash's Avatar
FYI, the term for absorbing water is hygroscopic.
Old Apr 15, 2008 | 10:24 AM
fishface's Avatar
fishface is on a distinguished road
taking the cover off and putting back on you should not have to bleed the system is the pushrod in the the right place
CrickiKaze
Mar 19, 2014 12:06 AM
Crashrat
Oct 11, 2012 08:25 PM
rafbo
Jul 16, 2011 10:24 AM
acarp
Sep 20, 2009 11:14 PM
supertwinSH
Oct 30, 2007 09:38 AM
