removed sproket cover...no clutch needs bled?
i did search and i found my answer (i think) but looking for confirmation...took off the front sprocket cover to clean the gunk out of it, put it back on and now i have no clutch. does it need to be bled? that seems to be what i'm finding using the SEARCH :)
thanks andy |
yes it does.
I've pulled mine off and Reaper's to change sprockets and we bolted them right back on with no problems.
(Post 158815)
Removed mine, and the cover won't go back on. Didn't touch the clutch rod or brake lever.
Drained the fluid - same problem. |
Check alignment as other said. I've had mine off and didn't have to bleed it. It seems that the rod will come out slowly on its own if there nothing to stop it. If your fluid level was low you could have sucked in some air when it extended out. You can try holding the clutch in overnight with tape or something to the grip and see if it helps... This trick works well on spongy brakes - I take it that it allows the air bubbles to rise up and self bleed.
Originally Posted by RickB
(Post 158837)
To avoid this problem in the future just pinch the hose with vise grips and something to protect the the hose.
I wouldn't squeeze the hose. The recommended way is to put a tie wrap around the clutch lever and grip. That will keep the slave from working its way out.
(Post 159292)
(Post 159292)
LOL!! ;)
Originally Posted by superhawk22
(Post 159660)
As long as you don't mash the thing the only way something would happen is if there was already something wrong with the line in the 1st place. I've done it for years and they even make tools to do it but do as you wish.
You can remove the clutch slave cylinder and replace it without re bleeding as long as you do not touch the lever. Although it’s never a bad idea to flush fluid and re-bleed the system. All but silicone fluid is hydroscopic so, once the container is open, it’s absorbing water. Change often and your better off. |
The point is that once it's flat most newbies are in an uphill fight to get it reinflated. I know I was when I did mine the first time - what a pain in the ass!
A Mighty-Vac or similar contraption available at most parts stores is a valuable tool. Usually about $50 for a decent setup. There are two players with these hydraulic systems. One is the size of the uptake of the master cylinder and the other is the viscosity of the fluid. Because the uptake of the master cylinder is microscopic and the fluid doesn't readily run down hill, pumping the lever is like - well, you know. The fluid is best drawn through the system via a vac that encourages the fluid to move. Under negative pressure the master allows much more fluid to enter the system than under normal lever conditions. My first attempt was a four hour mess that ended up all over the shop floor due to a bad kit. When TxSuperChicken and I overhauled the MC this winter we had pressure up in ten minutes and had the fluid changed out to dot 5.1 in about another three. Lesson learned here. He pumped up the system with dot3 because of the viscosity issues with the other fluids. Once it pressurized - we pumped that all out and used the old fluid to draw the new fluid in. Worked great! |
FYI, the term for absorbing water is hygroscopic.
taking the cover off and putting back on you should not have to bleed the system is the pushrod in the the right place
