To remove the rear, or not to...
Old Dec 29, 2010 | 07:34 PM
ranchomice's Avatar
I'm going to remove and replace a rear shock and I'm seeking direction. Is removing the rear wheel a must? Also, any problems with suspending the bike from the rear subframe? Oh yeah, one more thing, what (if any recomendation) does the shock itself get torqued to? My "real" computer crashed so I can't even read the disk with the manual on it. Any suggestions are welcome!
Old Dec 29, 2010 | 08:30 PM
You can suspend the bike by the rear subframe & just drop the shock out the bottom. I built these stands to do it & just put a barbell bar across them to hold it up.
Old Dec 29, 2010 | 10:50 PM
AngryOlaf's Avatar
Hi Ranchomice,
I notice the "soon to be installed.." on your signature. You're going to love it!
Be warned... I was able to lift my bike with a winch and drop the stock shock out the bottom, but ended up having to remove the entire header to get my JDM converted F4i shock installed... Not a lot of room down there and the new shock is a bit bulkier.
Old Dec 29, 2010 | 11:03 PM
Just_Nick's Avatar
Who are you?
I installed and uninstalled a longer shock without taking off the header or the rear wheel.
Old Dec 30, 2010 | 12:01 AM
ranchomice's Avatar
Thanks guys. I found the manual on the forum so the only other question is, do I need to replace the top mounting bolt? It says "install new" in the manual. PS. I'm not installing an F4 mod. I had him revalve and respring a stock VTR shock.
Old Dec 30, 2010 | 06:47 AM
t-dogg's Avatar
The easiest way I found to change the rear shock is to put jack stands under the foot pegs. There is no need to change the top bolt. On mine I had to use an impact wrench on the top nut to crank it down and keep the shock from spinning on me.
Old Dec 30, 2010 | 11:53 AM
Phone call returned........ Questions answered.....
8541Hawk
Jan 21, 2013 01:28 PM
nativegolf
Jul 1, 2007 06:50 PM
Texassuperhawk
Mar 10, 2007 10:06 AM
RedHotFireStorm
Dec 11, 2006 05:44 PM
EngineNoO9
Nov 11, 2005 09:16 PM
