stupid question... what do I need to remove front wheel
Old Nov 11, 2005 | 01:36 PM
EngineNoO9's Avatar
I'm assuming I need a front bike stand plus maybe a rear?? My old bike had a center stand so I never really thought about it when I got new rotors... heh if someone local wanted to be a kick *** guy and help me out that'd be even sweeter. heh
Old Nov 11, 2005 | 04:55 PM
NOrrTH's Avatar
Re: stupid question... what do I need to remove front wheel
I think in order to use a front stand, you need to have a back stand otherwise you need to hang the front from the lower triples. A cherry picker works or a rafter.
Old Nov 11, 2005 | 05:46 PM
superbling's Avatar
Before you start, break all necessary bolts (brake calipers, axle, axle pinch bolts). A rear stand and a jack underneath the front of the engine (as far forward as possible) works well. I never done it but some have said you can use a jack with the side stand (extreme caution).
As north said, ratcheting tie downs or a come-along from the front end to the rafters or some other sturdy overhead truss is the best way. Use the jack to lift the bike and cinch up the straps as you go. You'll need to get the tire a good 1 to 1 1/2 inches off the ground to clear the fender.
Support the brake calipers so they don't hang from their lines. I use short bungee cords.
Get a clymer or hayes manual as the factory manual usually skips stuff like this with general directions like: "remove front wheel".
Old Nov 11, 2005 | 06:32 PM
superhawk22's Avatar
Also when you put it back together tighten everything else but keep the pinch bolts loose and put the front wheel up againts a wall. Without using the brakes bounce the front end a few times. This sets the fork tubes evenly so there's no stiction, then tighten pinch bolts.
Old Nov 11, 2005 | 09:16 PM
EngineNoO9's Avatar
well I'm gonna goto the duncan dealer locally and see if they can help me out... If it costs $20 for them to install it or something (shouldn't be more then an hour labor) then fine... If they're real cool they could let me do it in the parking lot for all I care. should be difficult...
jon1475
May 17, 2013 10:21 AM
Tormoz
Jun 24, 2011 11:36 AM
dshakes
Apr 26, 2010 05:34 PM
TheDarkKnight
Aug 1, 2007 09:00 AM
The Hawk Guy
Jan 19, 2007 03:11 AM
