Preemptive CCT and R/R replacement?
Old Aug 15, 2018 | 06:21 PM
RJF53's Avatar
RJF53 is on a distinguished road
So I just picked up a really clean 2000 Superhawk. Very well cared for and only 5100 miles. I changed the fluids and had new tires put on today at a reputable local shop. I asked the mechanic to take a look at the CCT and he said it is original and in great shape. I've read on here that this is a weak spot as well as the rectifier/regulator.
Should I have these items upgraded even though they appear to be operating as intended?
Old Aug 15, 2018 | 06:55 PM
Yes.
Old Aug 15, 2018 | 08:47 PM
I’d love to know how the mechanic did his nondestructive material analysis for condition and metallurgy of the thin wire spring which the OEM ACCT relies upon to not catastrophically fail
i’ve worked with a few material laboratories they could do it but can’t say I’ve ever met a mechanic that could
yes do your own research make your decision either replace the cam chain tensioner‘s with brand new OEM automatic units and then replace them again at regular intervals or change to manual camp chain tensioners and never worry about it again
The regulator rectifier is also a no brainer.The old style diode based unit will fail today tomorrow next week or next month when it does it will also likely take out the battery some wiring connector or two and if you’re really unlucky your instrument cluster
The regulator rectifier is also a no brainer.The old style diode based unit will fail today tomorrow next week or next month when it does it will also likely take out the battery some wiring connector or two and if you’re really unlucky your instrument cluster on the other hand you can replace it at very reasonable costs with a MOSFET regulator rectifier and never worry about it again
Old Aug 16, 2018 | 04:53 AM
Protect your investment and get them swapped! They could last a day or a year, it's a gamble. These acct's are still failing on a regular basis, as seen on the more frequented fb groups.
Old Aug 16, 2018 | 05:16 AM
RJF53's Avatar
I'm convinced. Ordering replacements for both today. Thanks for the info!
Old Aug 16, 2018 | 09:55 AM
Yeah I was kinda curious as well as to the exact technique used to determine how a CCT is "in great shape." Why take a chance if given the opportunity to upgrade? Do those two things and the bike is basically bulletproof.
Old Aug 16, 2018 | 10:14 AM
I know a guy....................
Superhawk Mosfet RR Kit $120.00
Old Aug 16, 2018 | 10:26 AM
RJF53's Avatar
Perfect. I'll take one!
It looks like the option of choice for the tensioner is the APE Manual CCT. Is that what you would suggest?
Old Aug 16, 2018 | 10:36 AM
I think any of them work, some work better than others.
Right now I really like the APE Pro, is cleaner, its RED....lol, it works.
I've had the standard APE on my first VTR, the Krieger's and now the APE Pro on my current VTR.
Old Sep 7, 2022 | 05:55 PM
grampi50's Avatar
grampi50 is on a distinguished road
I just blew beer threw my nose! That's hilarious! It must have been that 6 week class he took to get his apprentice cert...
SifuDank
May 18, 2012 01:45 PM
viperslayer09
Nov 9, 2010 02:15 PM
cperson
May 21, 2009 12:30 AM
superbling
Mar 10, 2008 03:02 PM
KindredGhost
Mar 8, 2008 08:38 AM
