Preemptive CCT and R/R replacement?
So I just picked up a really clean 2000 Superhawk. Very well cared for and only 5100 miles. I changed the fluids and had new tires put on today at a reputable local shop. I asked the mechanic to take a look at the CCT and he said it is original and in great shape. I've read on here that this is a weak spot as well as the rectifier/regulator.
Should I have these items upgraded even though they appear to be operating as intended? |
Yes.
I’d love to know how the mechanic did his nondestructive material analysis for condition and metallurgy of the thin wire spring which the OEM ACCT relies upon to not catastrophically fail i’ve worked with a few material laboratories they could do it but can’t say I’ve ever met a mechanic that could yes do your own research make your decision either replace the cam chain tensioner‘s with brand new OEM automatic units and then replace them again at regular intervals or change to manual camp chain tensioners and never worry about it again The regulator rectifier is also a no brainer.The old style diode based unit will fail today tomorrow next week or next month when it does it will also likely take out the battery some wiring connector or two and if you’re really unlucky your instrument cluster The regulator rectifier is also a no brainer.The old style diode based unit will fail today tomorrow next week or next month when it does it will also likely take out the battery some wiring connector or two and if you’re really unlucky your instrument cluster on the other hand you can replace it at very reasonable costs with a MOSFET regulator rectifier and never worry about it again |
Originally Posted by RJF53
(Post 407279)
I'm convinced. Ordering replacements for both today. Thanks for the info!
Yeah I was kinda curious as well as to the exact technique used to determine how a CCT is "in great shape." Why take a chance if given the opportunity to upgrade? Do those two things and the bike is basically bulletproof.
(Post 407284)
Superhawk Mosfet RR Kit $120.00 |
(Post 407290)
Perfect. I'll take one! It looks like the option of choice for the tensioner is the APE Manual CCT. Is that what you would suggest? |
(Post 407291)
It looks like the option of choice for the tensioner is the APE Manual CCT. Is that what you would suggest? Right now I really like the APE Pro, is cleaner, its RED....lol, it works. I've had the standard APE on my first VTR, the Krieger's and now the APE Pro on my current VTR. |
(Post 407281)
I’d love to know how the mechanic did his nondestructive material analysis for condition and metallurgy of the thin wire spring which the OEM ACCT relies upon to not catastrophically fail |
