Over heating 996
Old 05-21-2013, 09:58 PM
LuvMy996's Avatar
LuvMy996 is on a distinguished road
Over heating 996
Hello to all. I just joined the forum. I have a 1999 Superhawk and seems when I do some good distance ridding my bike wants to overheat. I have checked the pump and know that it is connected to the motor and it works fine when the bike is on. Fans working fine. Flushed it and put in new coolant. But seems that no matter what it goes past the half way point on the guage and to the touch it seems to me to be hot. One time last season it got so hot it released to the overflow tank. No coolant in the oil or anything like that. Only thing I have not checked is the cap!! Can a pressure cap be bad if it does not leak? from the cap? And it is not over flowing to the overflow unless it gets to hot... Any help would be greatly appreciated...I just want to ride free and not worry about it...
LuvMy996 is offline
Old 05-21-2013, 10:11 PM
Change out the cap and you should be fine.
There is a Stant P\N if you want to save some $$ but you will have to do a search to find it.
8541Hawk is offline
Old 05-21-2013, 11:07 PM
Going past the halfway point on the oldschool manual gauage isn't overheating... It's normal... On that gauge, normal temp is between half and the next bar... After that, then it's actually overheating...
Tweety is offline
Old 05-22-2013, 07:59 AM
ascothawk's Avatar
ascothawk is on a distinguished road
radiator cap cross reference
An alternate to oem is Stant #10233 available at Advance Auto for 7.49. 1.1 bar=16lb. I found my gasket was split on the original cap while I was changing coolant. I also found my overflow bottle was plugged. I unhooked the overflow hose to drain the bottle and nothing came out. I used my compressor to clear the blockage while flushing the bottle with a hose and let the sediment float out.Just wanted to share this because the overflow function probably rarely gets tested
ascothawk is offline
Old 05-22-2013, 08:04 AM
+1 Do the fans kick off when at speed? What's your ambient temp?
7moore7 is offline
Old 05-24-2013, 04:15 PM
LuvMy996's Avatar
Thanks guys I will check the overflow and replace the cap. The ambient temp is to be determined have not rode her yet this year.. Going through the whole bike this year, brakes and so on. I appreciate all the feedback. Thanx
LuvMy996 is offline
Old 05-24-2013, 04:17 PM
LuvMy996's Avatar
Thanks for the cross reference also...
LuvMy996 is offline
Old 05-24-2013, 10:34 PM
GTS
Seasoned tech
GTS's Avatar
The recovery bottle should always have coolant rise up in it when the engine is hot. As the coolant gets hot it expands and pushes coolant to the bottle. If it's not pushing coolant into the bottle you are low on coolant. It should always have coolant up to the full lines and should go up and down as the engine gets hot and cools off.
GTS is offline
shadow623_
07-24-2014 03:23 PM
koth442
04-06-2011 08:38 AM
quinnkelli
02-16-2010 05:26 AM
K-Smoove
03-08-2009 11:14 AM
jserio
07-13-2008 03:40 PM
Quick Reply: Over heating 996
