My turn for a R/R failure
Old May 15, 2014 | 10:59 AM
KCCO's Avatar
Hey all,
Long time no post for me. I haven't been on the bike much do to a shoulder injury and some suspension issues. I finally got the suspension worked out, and an exhaust gasket so naturally I had to take it for a test ride. The test ride went fine and sparked the "Damn I really need to ride again" bug. With that being said I went for a commute ride in 101F heat and ended up burning up my R/R and melted the connector. One of my wires came out of the plug and grounded to the frame, which I think is that did me in. Thankfully I stalled out parallel to a gas station driveway, at a red light, one turn away from the highway on ramp. So Its time for a new one!
That is all, Ride safe Ride often!
Old May 15, 2014 | 11:26 AM
Good to hear from you, KCCO, even though the circumstances are less than ideal.
Old May 15, 2014 | 11:31 AM
rick's Avatar
rick is on a distinguished road
I just sent a reply to your PM on the other forum.
I recommend checking your stator as well and confrim it's not damaged before ordering new parts.
Fully Charge the battery, Leave the R/R unplugged and start the bike.
Now Measure the AC Voltage output Between the three stator leads. At Idle , 3k rpm and 5k rpm. The voltage should be close between each set of leads at a given rpm and they should start out at 10-20 VAC below 2000 rpm and around 70 VAC @ 5000 rpm .
If the stator doesn't check out buy a good stator as well.
I would test the battery as well.
Like I said in the PM I recommend not using an OEM style r/r connector anymore and go with the Furukawa QLW connectors.
Also eliminate the stock connector between the stator and the wiring harness.
Part of the reason for failures is the stock connectors corroding and weakening the electrical connection resulting in more resistance( and in turn more heat build up).
Old May 15, 2014 | 02:28 PM
cybercarl's Avatar
Good advice that rick.
It really surprises me the amount of members on here that either haven't replaced the R/R or go and replace with a non MOSFET. You guys have easy acces to a new MOSFET style R/R over there too. Unfortunatly over the pond it costs us a fortune for 2nd hand ones on ebay or if we want new we have to order from the states and then get hit by customs.
Old May 15, 2014 | 08:13 PM
GlockPointer's Avatar
Connie Demico does toad?
I was lucky and replaced my rr with a zx6 mosfet unit before anything happened. I cut the rr plug and soldered on females and covered them with heatshrink. Then I could still plug back in my oem rr if something went wrong. That was 10k miles ago and have had no problems.
johnclopp85
May 13, 2009 07:20 AM
Hawkrider
Aug 27, 2007 08:04 PM
vtrlvr
Apr 9, 2007 10:52 AM
jhaldin
Aug 23, 2005 09:00 PM
