Meaning of warning light
Old Nov 16, 2013 | 05:12 PM
oldguy50's Avatar
oldguy50 is on a distinguished road
Hi all, just brought home a '98 vtr1000 that I swapped for my turbo Civic. I didn't get any manuals with it, downloaded the service manual but I can't find out what the red "S" light on the cluster indicates. Also, the low fuel indicator is on and it's full. Other than that it's in really nice shape. My wife is thrilled.
If anyone can tell me what that lamp is indicating I'd appreciate it.
Old Nov 16, 2013 | 05:40 PM
insulinboy's Avatar
The only red light on the instrument cluster should be the oil light. There is a yellow S light though that lets you know the kickstand (S for sidestand) is down
Check the connector that should be between the front of the seat and the gas tank, thats your fuel level sender for the warning light. Make sure its plugged in and wiggling it doesn't change the light indicating the connector is shorted
Old Nov 16, 2013 | 07:37 PM
RWhisen's Avatar
Former Superchicken Owner
If your sidestand light is on you need to check the switch at the sidestand. It is a pretty common fault.
Old Nov 21, 2013 | 05:16 PM
bird-rider's Avatar
bird-rider is on a distinguished road
I agree the S indicator means that the side stand is still activated. Try to check the trigger switch, you can try to clean it out using a contact cleaner spray. About the low fuel indicator, check the connector worst would be a basted fuel level sensor.
Old Dec 8, 2013 | 09:04 PM
SIRR1's Avatar
Deals Gap is a Hoot!
SIRR1 is on a distinguished road
It's possible the previous owner had the counter shaft sprocket cover and the hydraulic clutch mechanism off the motor and pinched both the oil pressure switch wire and the kick stand wire when he reassembled or put the covers back on the engine.
The side stand switch may just need to be turned 180 degrees.
With the side stand switch off the bike and the VTR's key in the on position simply rotate the side stand switch until the light goes off them reassemble the switch.
Or you may need a quart of oil in the engine, This is where I would start by checking the engines oil level.
SIRR1
Old Yeller
Jul 18, 2011 01:40 PM
8541Hawk
May 1, 2011 12:48 PM
Bytes
Dec 17, 2009 03:21 PM
Randman
Dec 4, 2009 01:22 AM
Hawk9807
Sep 8, 2007 05:43 PM
