Leaky Forks???
Old May 18, 2005 | 07:41 PM
superbling's Avatar
Re: Leaky Forks???
Nope, not normal. I've had mine apart about 3 times in the last 6 months going from a 1.0 down to a .85 and then back to a .90 spring along with adding RT gold valves and changing out different weight fluids.
What do you mean by "serviced"? Did they install new seals?
How strict is the tracks' tech session?
Old May 18, 2005 | 08:50 PM
superbling's Avatar
Re: Leaky Forks???
I think you're OK. They probably just needed to seat in with a few good suspension strokes under pressure. Kinda' hard to do off the bike!
Old May 18, 2005 | 09:29 PM
jschmidt's Avatar
jschmidt
There is a problem. Seals either leak or they don't. There is no in between and there is no leaks a little bit after repair.
During assembly, the seals are lubricated with a little fork oil to aid in assembly. Its rubbed on with a finger. Is that the sort of amount you are talking about? It would be a tiny bit.
Seals will sometimes fail after R&R. But it would have to be filled way too high to the top to force any out on compression.
Another liklihood is that the wrong seals were used.
Old May 19, 2005 | 07:05 AM
L8RGYZ's Avatar
A buddy of mine installed some seals on mine & they leaked. The seals I had bought had some additional metal seals/shims in the kit. They were somewhat different than the stock seals. I told him to be sure & follow the instructions, but...you know how that works. He never read the instructions & so threw out the "extra" parts! Not confidence inspiring.
And don't get me started on mechanics & brakes!
VTRsupersport
Feb 29, 2012 05:09 AM
jbeber
May 17, 2010 02:11 AM
speedkelly@aol.com
Dec 4, 2007 03:10 PM
nuhawk
May 1, 2007 06:59 AM
xboxxer
Aug 16, 2006 12:24 PM
