Intermitent Blinker Issue
Old Feb 16, 2010 | 10:27 AM
996serrano's Avatar
996serrano is on a distinguished road
Smile Intermitent Blinker Issue
I did search and read through the other posts about this problem so please don't slam me just offering up how I fixed mine. I started having the issue last night with the flasher relay blinking really quick but the lights would not blink. I would fiddle with the switch back and forth and it work but only one side then it would act up again. So today I took apart the entire switch and got a battery terminal cleaner you know the small metal brush and i used that to scrub off all the crap on the actual switch. Then i spray a little wd40 inside the switch and used a tood brush and scrubbed inside the switch really good and got rid of all the grease and dirt in there and then dried everything with a clean rag. Reassemble and problem solved.
Old Feb 16, 2010 | 03:23 PM
PUSHrod's Avatar
Sounds good. Where do I go to get a tood brush?
WD 40 evaporates in a coupla weeks or so. Try 'Teflon' brand spray lube, when the carrier agent dries the teflon left behind is slick as snot and remains a long time. Works great on chains too, and doesn't attract road ****.
Old Feb 16, 2010 | 03:44 PM
Another good idea is to get some "dielectric" grease on the contacts to protect them from corrosion.
Old Feb 16, 2010 | 06:06 PM
996serrano's Avatar
Lazn that is what I will do nxt I just wanted to get my blink blink working. You know the knuckleheads here in Phoenix.
joshuatest
Apr 13, 2008 10:12 PM
killer5280
Oct 27, 2007 09:34 AM
VTRBandit
Jun 9, 2007 12:26 PM
fundgh
Apr 20, 2007 11:38 AM
bockspa
Aug 21, 2006 08:17 AM
