Idle RPMS
Old Jul 8, 2009 | 05:48 AM
dani p's Avatar
dani p is on a distinguished road
Idle RPMS
At what RPMs should the bike idle at on nuetral after warm up?.....
having different discussions and want to know your ideas from the experts.......
Old Jul 8, 2009 | 05:53 AM
anywhere from 1000-1200 rpm. Mine is usually around 1100
Old Jul 8, 2009 | 06:00 AM
dani p's Avatar
right now I;m below 1000....too low I guess....
Old Jul 8, 2009 | 06:48 AM
malahhaor's Avatar
malahhaor is on a distinguished road
Mine constantly jumps a coupe hundred up and down, don't know what's wrong.
Also sometimes it hovers at 1500 (up and down a cuple hundred) few lights down the road it will be around 1100 and also jumping up and down a few hundred RPMs.
Any ideas?
Old Jul 8, 2009 | 07:43 AM
divingindaytona's Avatar
Remember stock is BAD!
If I remember correctly the oil spec is 1150-1200.
Old Jul 8, 2009 | 07:46 AM
trinc's Avatar
i run mine a bit on the high side of the spec ~1300 rpm, dial it up more for the track.
tim
Old Jul 8, 2009 | 08:30 AM
Gorwin64's Avatar
Gorwin64 is on a distinguished road
the owners manual says 1200 plus or minus 100rpm
but it also says that you should shift into second around 13mph.... and be in 6th at like 55mph, so take it with a grain of salt
Old Jul 8, 2009 | 08:53 AM
Little_Horse's Avatar
2nd mouse gets the cheese
Any ideas?
An idle that wanders that much usually indicates a slightly lean idle so a half turn richer on the mixture screws should settle it down.
My bike bounces +- 100 rpm which I think is pretty normal, 400 rpm is not normal though.
Old Jul 8, 2009 | 10:24 AM
little squirt's Avatar
little squirt is on a distinguished road
mine sits at around 1200+/- 100
Old Jul 8, 2009 | 10:37 AM
rhorsley's Avatar
rhorsley is on a distinguished road
Mine sits at 1100 and almost never varies.
Old Jul 8, 2009 | 10:59 AM
swordfish's Avatar
same here. rock solid
Old Jul 8, 2009 | 11:00 AM
malahhaor's Avatar
Good to know, thanks much!!! i will check it out.
thedeatons
Jun 21, 2015 09:11 PM
codybrown
Aug 15, 2013 10:03 AM
snakeman34
Mar 26, 2007 08:46 PM
DaxMiddler
Apr 28, 2006 03:22 AM
EngineNoO9
Dec 22, 2005 01:06 PM
