I just weighed my bike...
Old May 12, 2009 | 11:34 PM
maverick's Avatar
407 lbs with a full tank of gas.
So, engine oil is close to one gallon, (7 lbs), I'm not sure about coolant since I don't have one of the radiators... Does a gallon sound reasonable? (I'll say 5 lbs) and 4.2 gallons of gas (25 lbs) brings it down to 370lbs dry, which is about 5 lbs less than a brand new gsxr1000. Since the dry weight stock is 423, that means I lost 53 pounds!
So with my +2 in the rear gearing, shift kit, ignition advancer, jet kit, k&n filter and a sizable weight loss, I think I'm gonna do ok at the track... I just need to finish making a chain guard (needed at the track) and find another snell sticker for my helmet (painted over) and I'm good to go.
I'm stoked to see how I do, especially after I SPANKED a 2003 r6 and a 2000 gsxr 600 yesterday. They were a bit surprised.
Old May 12, 2009 | 11:44 PM
killer5280's Avatar
Careful that you don't set a new lap record.
How did you get the bike so light?
Old May 12, 2009 | 11:58 PM
maverick's Avatar
no fairings, smaller headlight, small computer instead of gauge cluster, single radiator, single shorty exhaust, and single seat aluminum subframe are probably the big things.
Old May 13, 2009 | 05:05 AM
sumthin_major's Avatar
where's the pics of the bike?
Old May 13, 2009 | 05:12 AM
hawxter996's Avatar
ole dirty bastard
members galleries.
he won superhawk of the month.
Old May 13, 2009 | 06:22 AM
Pretty impressive
I'll have to get mine on the scale once everything is done....
Old May 18, 2009 | 08:42 PM
COLE's Avatar
Crash
i goin 2 check it out mav.
Old May 18, 2009 | 09:30 PM
Truckinduc's Avatar
mine is about 350 with oil and coolant right now. Ill add about 10 more lbs though
Old May 18, 2009 | 09:52 PM
Wow! That's about 75 pounds off stock wet weight if I'm correct. How do you keep the front end down?
Old May 18, 2009 | 10:01 PM
maverick's Avatar
It's a labor of love... lol It actually isn't all that bad. You have to watch first gear, and when you shift hard into second or third, but other than that it's totally manageable. I am buying a 15t countersprocket though, and that might make it a bit lighter in the front end...
Old May 18, 2009 | 10:29 PM
RK1's Avatar
RK1
The "dry weight" you see promoted by the manufacturers (423 lbs. for the VTR) is not just minus fuel. It's also minus oil, coolant and the BATTERY.
Per Sportrider mag a stock VTR is 477 lbs. with a full tank and 452 tank empty.
The weights some of you guys are reporting are down in Ti and cf laden MotoGP bike territory.
What does it weigh when you cut loose all those helium balloons you got tied to the tail piece? Just kiddin', but those weights sound pretty low.
Old May 18, 2009 | 10:45 PM
maverick's Avatar
yeah a giant steel subframe, passenger seat, passenger pegs, two giant exhaust pipes, fairings, headlights, gauges, one of the radiators and other bits and bobs weighs a lot man. You have a lot of useless crap on your bike. Trucks bike has none of those things either, and that's why ours weigh so much less than yours. And we are not exaggerating in the slightest. See the difference?
Old May 18, 2009 | 11:00 PM
RK1's Avatar
RK1
maverick;
Yeah I'm trying to have some fun, not calling BS.
Like I mentioned, the "dry weight" is without the battery. Going by the wet weight (477) you pulled off 70 lbs., not 53. That's pretty impressive. Curious to see what you'd do at the track 'cause -70 lbs. weight is the equal of +10 horse power.
Old May 18, 2009 | 11:04 PM
Truckinduc's Avatar
-70 lbs is also more importantly gonna mean better brakes, transitions, and all that stuff.
dropping weight helps EVERYWHERE
my gastank alone is 10 lbs lighter than the stock one.
Old May 19, 2009 | 03:05 AM
gboezio's Avatar
My bike is apart and when I move it around it just feels wonderful, the stock cans where plain huge chunks of steel, the rear tail section is pretty light, the tank is heavy and placed high, this is a good place to shed weight, then there's the rads with all the hoses filled with water, I might do a street fighter conversion with a single rad, I shortened the front header to make room for a front mounted rad.
A 520 chain, steel/al combo sprocket, lighter flywheel
Maybe a lighter battery or a kickstarter The weight of the right leg muscle may offset the weight gains after a month
Then cutting those huge crank counterweight with a blowtorch...maybe not
mike21091
Jan 28, 2013 03:46 PM
t99ford
Apr 19, 2011 08:49 PM
mikstr
Mar 31, 2007 10:46 PM
captainchaos
Feb 23, 2007 10:37 PM
EngineNoO9
Nov 20, 2006 05:08 PM
