How do they run stock?
Old 09-19-2009, 03:07 PM
Hawkagain's Avatar
Hawkagain is on a distinguished road
By stock I mean carbs, air filter & exhaust. Just as it came from Honda. I have read bits and pieces in jetting threads but too much completely stock. It seems like a shim to help cures most of the ills?
For those who run stock how does it run:
Off idle?
On the Freeway?
Midrange sport riding on/off the throttle?
What kind of fuel mileage do you get?
Mine runs pretty well everywhere but it is not stock.
Thanks,
Steve
Hawkagain is offline
Old 09-19-2009, 04:40 PM
Parental Deviant
punkwood2k's Avatar
punkwood2k is on a distinguished road
um.. it runs like its supposed to I guess?
I get about 100-125 miles per tank, depending on how I'm feeling that day.
punkwood2k is offline
Old 09-19-2009, 06:40 PM
thumper61713's Avatar
thumper61713 is on a distinguished road
I have everything stock and I think my bike runs really good!! Of course I want to get new exhaust, jet kit, air filter, 520 conversion kit, remove pair system, install speedohealer, racetech forks etc...
Idle seems pretty good, gas mileage is about 130 miles per tank depending on how fast I go
I think there is a little bit of lag time when I grab a handful though, I would like my bike to be a little more responsive, I think upgrades will take care of that
thumper61713 is offline
Old 09-19-2009, 06:48 PM
RickB's Avatar
Mine ran real well in stock form with 41-43 mpg... I have shimmed the needles and added a K&N but otherwise still stock and 41 avg mpg.
RickB is offline
Old 09-19-2009, 09:17 PM
Red_Liner740's Avatar
well apparently they are jetted really lean for emmission purposes, especially at lower RPM, hence that hesitation once in a while that is cured by the shimming of the needles...
to be honest, they are such temperamental bikes its hard to tune them...i had mine tuned spot on with a DJ stg 1 kit and yet sometimes it'll run beautifully and other times it'll stutter at low rpm. i learned to live with it.
Red_Liner740 is offline
Old 09-20-2009, 07:39 AM
When I had a brand new one it was everything cycle world said it was. Unlike the abrupt throttle response of the fuel injected TL they said the superhawk had "the type of linear throttle response that leaves you wondering why we even need bother with fuel injection." I've since owned several more and have never experienced any hesitations or jetting issues on any of them with stock jetting, and it also never mattered the exhaust I had on it either.
captainchaos is offline
Old 09-20-2009, 11:10 AM
Remember stock is BAD!
divingindaytona's Avatar
After putting in a jet kit this is what I noticed.
Originally Posted by divingindaytona
I put in a factory jet kit a while ago now went off there "suggested setting" for the set up that I was running. Took her out and then had to do some tweaking.
So after pulling the tank and carbs 2 times (pita) got her tuned in well.
After riding her for awhile now I notice that she
1)Pulls stronger - all over
2) Has more top end power - she use to ge up to 8K and then fall flat on her face
3) Has less vibration- running at 2K rpm's in 6th gear if you crack the throttle I use to get bad vibration (yes the carbs were synced to within spec)
4) Wheelies easy'er - like it had a problem with that before
I havn't noticed that my gas milage has increased as some people have suggested, but I do have a heavy throttle hand.
The tone that people have with regard to a jet kit is it is hard to tune and is generally a pain in the a$$.
They don't mention that the hassle is worth it, so I am! You get a bike that is smoother, stronger and has no/little flat spots. It also takes care of a few minor annoyance that the Shawks have.
Taken from this post
https://www.superhawkforum.com/forum...ead.php?t=6541
divingindaytona is offline
Firehawk_ordie
Motorcycle News
24
04-30-2007 10:46 PM
Auron
12-11-2006 08:03 PM
Randman
11-20-2006 03:08 PM
Nighthawk
10-06-2006 06:19 AM
omniouslink
09-12-2006 09:56 AM
Quick Reply: How do they run stock?
